Misalignment of the belt, incorrect belt, worn or loose tensioner, Too tight of an adjustment (many service centers do this on purpose so when the belt breaks in it becomes properly adjusted, I do not believe in this philosophy), The belt is actually one long belt called a serpentine belt.....
sounds like your powerboard, you can try a cheap fix by putting a small fan behind the tv on low and see if that helps. Also I would not settle for this and call in the warranty and get it fixed while you can.
We usually find this is the cabinet back rattling. To confirm, when this happens turn the volume on the set all the way down and see if the problem is still there. If it is still there the put your hand on the back of the tv and gently press to see if the buzzing goes away. If the sound does go away the cure is to loosen all of the back cabinet screws around the edges of the set and gently push on the back as you tighten the screw. tighten the screw in an order much like you would tighten the lug nuts on a tire. in other words thighten the top left screw, then the bottom right screw and kepp alternating as yougo around the dabinet back untill they are all tight.
