If you have gone into the customer menu and selected convegence--is blue or red out of place and will not adjust?
Akai is a brand name and the sets are actually SAMSUNG---this model
(pt5598) uses two STK-392-040 CONVERGENCE CHIPS.
If convergence is your problem--both chips need to be replaced--there are also some fuses near them that sometimes fail---not the most easy set to do this kind of repair on.
If it is not a Convergence problem---Only one other possible thing happens with these=====if you turn the color off or go to a black and white program----does the screen have a yellow looking cast to it?
This may be mostly in the center or top etc ---let me know if it is convergence or the YELLOW looking screen and I can tell you exactly what the problem is and if it is worth fixing.
I am here to help
SD TECH
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
The blue is not adjust
