I have a kenmore chest freezer with a power light on the top, the light will blink on and off and once the freezer turned off altogether, what could the problem be
The Power On light is neon. They will, as they age, start to flicker and flash rapidly. As long as it remains on, it is fine and can be ignored. If it goes out, then it should be replaced by a qualified Kenmore or Frigidaire tech.
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
I think I have the same problem. The light on the front of the freezer blinks rapidly constantly. I have no issues with the freezer working though. The fact is blinks is enough to bother and worry me. Manual says the light is only to let you know power is being supplied to the freezer, nothing more, nothing less.
freezer's electrical plug shorted and the circuit breaker activated. This is a 30 yr old Sears chest freezer.
Should it still run when power is turned on (after plug repaired)?
Key goes in but will not unlock top
