Canon PIXMA  MP510 All-In-One InkJet Printer Logo
Posted on Oct 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon mp510 error code 5400, printer switches on nothing works and error code comes up
Anonymous
Level 2:
  • Expert 117 Answers
  • Posted on Oct 13, 2009
Anonymous
Expert
Level 2:
Answers
117
Questions
0
Helped
58634
Points
238
Paper feed error [5400] Replace the printer as it has failed.
I am getting a B200 error code on my canon printer...It is a canon MP510 printer
The error in Canon Printer Error Code B200 indicates a defective print head. A print head is an element that actually allocates the ink onto the paper from the cartridges, which ensures that it is one of the most critical aspects of the printer as a whole. Canon Printer Error Code B200, which can signify a hugely damaging system error, is one of the most feared.
Try these fixes before you go replacing your entire device. Follow this step given below.
1. Restore the doubtful cartridges
2. Extract and clean your printhead
3. Reseat your printhead
4. Check for obstructions
Solution - Canon Printer Error Code B200
Error code 5400
This error related to the internal temperature being out of normal range. If the printer has been used for high volume printing recently then simply unplug it and let it cool down.
If this does not help then replacing the printer is much cheaper than a repair job!.
I hope this helps
Regards GM
Canon MP510 printer won't scan from its program in PC-code 1,0,0
The problem was that all of the C.D. files were not loaded at start up. Thank You for Now. AEF
Error code 5400
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2helpful
Error 5400
5400 is an internal temperature error that usually shows up when the main logic board goes bad. The price to replace it is probably more than a new printer.
Printer won't print
Try the following: Switch off and unplug the unit, 1) Open the unit and remove the covers that can be removed. 2) now look for any object or blockage in that unit, if none then move the moveable part with your hands, if it moves freely then close the unit after you cleaned it out with compressed air.3) Secure all removeable parts firmly and restart the device. If that doesn't help, I will try and find the correct solution for you.
1helpful
Error code 5400
go online and type in following information"
canon printer errors code 5400
enter
rod
Canon MP510 Error code 5100
Ink cartrige is in the wrong slot and now oth are stuck!!! what do i do????
old marine
old marine
ZJ Limited
ZJ Limited
