Microsoft Xbox 360 Console Logo
Anonymous Posted on Oct 12, 2009
My xbox360 turns on and I have audio but there is no picture of any kind.
Anonymous
Level 3:
President:
  • Master 1,179 Answers
  • Posted on Oct 12, 2009
Anonymous
Master
Level 3:
President:
Answers
1179
Questions
Helped
422770
Points
3751
This could have a few causes. 1. Try running a good quality DVD cleaner as you may have a dirty lens. 2. Check your connections to the TV to see if the cable has come loose. Or 3. Check the wire to see if it is frayed or cut and if it is replace. You can also check by using a different set of jacks on the TV, if equipped, to see if it is a TV problem. Also make sure you have the TV on the proper settings to play as if it's not on the right video input it will play sound but not have a pic. Hope these tips help you. Good luck.
Testimonial: "This was helpful but not successful"
1helpful
How do I hook up a 360 the magnavox. T.v
Your picture is small, but it looks like you've got available HDMI jacks on it. if so, connect and HDMI cable between the Xbox360 and you're done! High Def video and audio will be sent to the TV when you select the input that matches the one you've connected the Xbox360 to. More details linked below:
How to hook up your Xbox 360 or Xbox 360 to TV
tip
Psp ps2 ps3 xbox360 netindo repain in mubai and in navi mubai and in andheri and...
9867244969 Psp repair in Mumbai , ps3 repair in Mumbai , xbox360 repair in Mumbai , ps2 repair im Mumbai psp repair ps2 ps3 repair xbox360 repair 9867244969 psp modchip Hello all We are specialist of all kinds video game. We have 10 year experience. We stables 1999 year We are sales and repair shop. We are can repair all kinds of problem Ps2 : modchip, lanes, no power, no video, mother board change any IC, no disc reading Ps3 : power light only red, no video, no disc reading, disc error, on after become red light, ps3 red light, PSP1000, psp2000, psp3000 : all software and hardware, psp hack, psp games, psp firmware psp custom firmware, chicken, LCD, display, psp adapter Xbox360 : 3red light, 2red light, open tray, disc error, latest game not working, xbox360 hack, xbox360 spftmod , xbox360 adapter Wii : power problem, disc error, 003 error, wii softmod, wii hack wii lanes, wii adapter NDS lite : power problem, LCD problem , no cartridge, no SD card sony service center contact person seraj 9867244969
How connect to BenQ mp620p- xBox360 ? Thanks good luck
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
Cant turn the TV speakers on
YOU HAVE TO PLUG AUDIO CABLES(RED ANDWHITE) AS WELLA SCOMPONENT VIDEO.
COMP VIDEO IS ONLY PICTURE
Audio and video problems
We can fix this for you. We are a listed repair service on this site. Check out our low price on xbox360 repair service.
www.videogamerepairservice.com
My Xbox360 elite console is having trouble with audio and video. The Xbox turns on but there is no picture or sound out of the T.V and it does this on every T.v to. How do I fix this problem?
If you have been using the same cord to hook up your console then it might be damaged. I would recommend trying to use a different cord if you can.
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
No picture but have sound
If you want to solve soon the xbox360 problems like 2red lights problem, 3red rings problem,E74 error,audio but no video, audio but no picture, 3flashing red ring problem, red ring of death problem, rrod, ring of death problem, Disc read error, One red light problem, freeing problem, then you should have to Click Here.
Cable box HDMI connection probelm
This is from the Yamaha user guide:
The analog component video signals (with 480i (NTSC)/576i
(PAL) of resolution only) are converted to the S-video or
composite video signals and output at the VIDEO or S VIDEO
MONITOR OUT jacks.
The question is what kind of signals you get from your HD cable box.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
