If I got the issue correct the washing machine is leaking specially from the in front of your top loading washing machine.
Leaking water from a washing machine usually comes from hoses or
connections. Be sure that water appearing to be a leak isn’t drain
water from a backed-up standpipe. To prevent potential flood damage,
which can occur if washing machine supply hoses burst, be sure to
install “no-burst” stainless-steel mesh hoses and lever-type shutoff
valves, as shown below. With these, you can easily turn off the levers
for both hot and cold water between wash days.
1) Check the fittings where the hoses connect to the faucets and to the
back of the washing machine. Also look for worn or leaky hoses. Tighten
couplings or hose clamps if needed, or replace the hoses altogether. Be
sure to turn the water off before removing the hoses, and drain them
into a bucket after disconnecting them.
2) Determine whether the machine is overwashing, which can cause the
machine to overflow. Reduce suds by pouring 1/2 cup white vinegar in 1
quart water into the washer. Then switch to either less detergent or a
low-washing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing
that must be replaced; in this case, call an appliance repair person.
Thank You for contacting fixya.com
