The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC
it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer
I await your reply if you have any further questions Thanks Rick
