My motorola v600 can no longer display any web pages. I have performed a Master reset, checked the Tesco WAP settings and downloaded and installed the Tesco GPRS WAP1 settings. When I try to launch WAP, GPRS WAP1, MMS or try to go to any other URL, the phone connects (or appears to!), data is transferred, but everytime it comes up with: "Page cannot be displayed" or occasionally with: "Sorry" or with: "Entity requested is too large". Additionally, I have also set up my email settings (which I know are correct because they work on my other phone) but cannot send or receive emails, as the phone fails to connect to the remote server (I suspect that this may be a consequence of the first problem)
I do however still get charged for data that occurs during all these unsuccessful attempts to open up web pages or use email.I would appreciate any advice.
Go to this site and sign up to become a member. (It's fast and free.)
The site has a download link for the Motorola Tools (PC) Suite - and PC
Driver download. (All free)---
You can perform a master reset to dissolve any glitches, bugs or other complications you experience with a Motorola Razr V3x. According to the device's user guide, a master reset will reset all options in the phone, with the exception of the "unlock code, security code and lifetime timer." Back up any data, pictures, or contacts you wish to keep before performing a master reset on the Motorola Razr V3x
1 Navigate to the "Settings" menu using the directional arrows. Click the "Setting" option with the "Center" key on the phone.2 Press the "Center" key to choose "Initial Setup" from the Settings menu.3 Press the "Center" key on the keypad to select the "Master Reset" option from the Initial Setup page.Thank you for using Fixya
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3: 1. Open your phone up and go to “Settings” 2. Next go to the selection for “Initial Setup” 3. Next go to the selection for “Master Clear” 4. Then select to confirm the option. 5. Now enter the security code which should be “000000” 6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post: hard reset motorolla razr v3 hard reset razr phone wii master reset hard reboot motorazr how to hard reset a razor v3 master reset code for motorola v3 master reset code razr v3 master reset for v3 via pc master reset motorola razr 2 master reset v3 razr with white screen motorola v3m master reset p2k commander razor master reset razr 3 and how to reset razr master reset ebay razr master reset password razr master restart razr screen master reset reset razr reset razr to factory reset razr v3 to factory v3 hard reset razr v3 razr reset hard boot
Cloning
These radios support cloning parameters between a master and slave radio.
Cloning only transfers the user's settings from the master radio to the
slave. Things like tuning values, serial number, etc. are not changed.
To clone a master radio to a slave (target), perform the following:
Make sure both radios are off
Connect the cloning cable between the two radios through the programming
port
Turn on the slave radio
Press and hold the "A" button on the master radio and turn it on
The master radio will display CLONE if cloning can proceed, otherwise
an error will be displayed
The slave radio will display PROG while it is being programmed
When cloning is complete, the master radio will display END and the
slave radio will reset automatically
Changing the Active Line:
Change the active phone line to make and
receive calls from your other phone number.
Note: This feature is available only for
dual-line-enabled SIM cards.
The active line indicator in the display shows the currently
active phone line (see page 28).
I hope this is what you were looking for.
