You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
In DSCT2 Camera, the C:13:01 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Internal Memory or with the Memory Stick.
The Symptoms are:
1. Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
2. Unformatted "Memory Stick Duo" which can be resolved by formatting the MS in the Camera.
3. "Memory Stick Duo" is broken or not compatible which can be resolved by inserting a new compatible MS.
4. There may be an issue with the Hardware part also, which can be resolved by the technicians.
Try turning the power off and on again, or taking out and inserting the "Memory Stick Duo" several times may also help in resolving the issue.
Thanks.
