SOURCE: How to open the back of Frigidaire FEX831CS to change belt.
Remove the two screws from the bottom of the FRONT panel. The panel drops down and pulls off. You change the belt from the front
SOURCE: The dryer to my Frigidair FEX831CS top Loaded
Could be one of 4 problems:
All of the above are easy do at home repairs if you re handy. You should be able to get a good idea of what is wrong just by turning the dryer drum by hand. If the problem is the front bearing or guides, you will hear a grinding noise in the front at the top of the door.
Below is a link to diagrams and parts for your dryer. - J
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158202&diagram_id=1300060#d1300060
Thanks for using FixYa - a 4 THUMBS rating and POSITIVEComment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Hello Jennifer Christie, thank you for your post!
I see that you have replaced the belt and bearing drum in your Frigidaire dryer but the unit does not start. It sounds like you could be experiencing an issue within the motor or timer. I would recommend having a professional come out to properly diagnose and repair your appliance, to avoid any further unnecessary part purchases. I hope this is helpful. -Matt
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Hello trinileigh19 - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
