IBM ThinkPad T20 2647 Notebook Logo
Posted on Dec 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Operating system not found, hard disk not found message showing in IBMT20
I have IBMT20 and operating system is Windows XP. I installed QTP in this qtp is not insatalled and it is showing a message is that Operating system not found, hard disk not found. I had shown to service people, they tried to install operating sysytem xp not done then tried with Windows2000 but laptop wsa hanged. Cound pleas help me in this regard.
  • Anonymous Mar 15, 2008
    i removed my memory and put it back so when i turn on my computer the screen is dark and i hear beaps before that.
  • chanchol May 11, 2010
    Dear,
    i have T20, the problem is
    "Operating system not found, hard disk not found"
    Chanchol
    [email protected]
Win Password
Level 2:
  • Expert 102 Answers
  • Posted on Nov 27, 2013
Win Password
Expert
Level 2:
Answers
102
Questions
0
Helped
27147
Points
173
On my ThinkPad Notebook Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
jim griffin
Level 1:
  • Contributor 3 Answers
  • Posted on Jun 04, 2008
jim griffin
Contributor
Level 1:
Answers
Questions
0
Helped
924
Points
5
Drive is not seated properly ,OS not installed correctly or boot sector damaged.Getting the T20 HDD istalled can be tricky if any of the pins are slightly bent .
These can all be repaired,unfortunately the actual HDD connecter on the board may be damaged as sometimes happens &really means the end for your laptop
Thomas Christopher
Level 3:
Genius:
  • Master 1,601 Answers
  • Posted on Dec 26, 2007
Thomas Christopher
Master
Level 3:
Genius:
Answers
1601
Questions
Helped
1052871
Points
3958
Your hard drive is most likely bad or the ribbon cable is not connected.
there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
1helpful
Hello, I have a problem with my computer, I think all started with a virus when downloading a program to diagnose the pc or a driver for the modem, try removing the virus with several antivirus with no...
I think you just erased your hardrive. (Or it wouldn't show the Operating system not found message).
That means your data is already lost. (Unless you have 2 harddrives in your pc)
Get a Windows Installer CD from a trusted source. ( Maybe the local computer store can lend you one)
Test this cd on another pc (By just booting the cd , not by running the installer!)
Install Windows using this cd (Start it using F12 like you said)
My operating system is XP S3 Antivirus - Norton
that's common in norton that's why i'm not using it anymore,they are repeating scanning virus even you delete or remove..and they also hard to remove from your system..on my part i restore my system to when before i installed norton..so do the restoration system
2helpful
3answers
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
4answers
When i turn on my laptop it says invalid system disk.replace the disk and then press any key
You probably are using Windows XP. With this error, you must re install your Windows XP operating system with your XP CD.
1helpful
3answers
I can't boot up the Vista install on a Sony Vaio VGN-NR160E
go to your BIOS Setup, see to it that there is a Hard Disk Boot Priority, maybe you didn't put it there.
Hard disk formetting
hi,
I think low level formatting should do the trick. you can download it and its free. In your case try to download the DOS based version. This type of formatting erases the entire disk clean.
1helpful
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Get error message "operating system not found"
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
3helpful
2answers
Having problem installing Windows XP on My Acer Aspire T650 Computer
Before you did the install did you make sure that you set your CMOS setting to check for a cd disk first before booting straight to the hard drive? When you do an install, you must make sure that the computer knows to look for a bootable disk otherwise it will look for an operating system to boot to first. If this is the problem, after you have installed your operating system you must go back and reset your CMOS settings to look for a hard drive or operating system. Hope this help and if it doesn't let me know for further assistance.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
