Cavs DVD-105G Logo
Kimberly Hoflich Posted on Oct 11, 2009
I have a cavs dvd-105g and when i put a disk in it is says no disk.. what is the problem with this.. it is a new machine,
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 23, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1323
Points
I also have a cavs machine.......when it does this I open the cassette and reinsert, it usually loads....another idea, open the machine, access the laser, you may have to remove a cover over the laser, and clean it.....also, some models have a software glitch.....so when it does this....shut the power off w the remote.....wait a few seconds, power it back up....and let it load the disc......question, does it do this w all discs?
2answers
How do I fix the vga output in my cavs 203g Karaoke player
what is wrong with the VGA output? the connector? no display? please clarify
1helpful
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
    The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
    As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
    The following is the advertised support for your unit, hope it helps:
    Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
    New Cavs 105G
    I would clean the laser
    1helpful
    Unable to read a disk that has not been finalized unless new
    It sounds like the most like culprits are the laser assembly or it could be the Mpeg printed circuit board, often found attached to the laser assy by flat ribbon cabbles. the part number should be on the printed circuit board or laser assembly, otherwise obtainable from their closest aurthorised dealer. Good Luck.
    CAVS DVD-203g remote control
    my cavs203g video out put doesnt work and dont have remote
    2answers
    CAVS DVD 105G having trouble reading super CD-G disc
    just got the CAVS 105G and the tray will not open.  Could there be a shipping brace that needs to be unfastened in order to open the tray?
    Durabrand dur-1700 portable
    its the disk not the machine put one of last years disks in and try it
    new disks have new formats that older players cant recognize now the corprate industry maken money by selling bogus disks so where you have to upgrade your players which means buy new ones
    No Disc
    This maybe due to a disk misread, clean youe lens and retry. If this does not help you may have a problem where the system is unaware of the disks it shouldbe able to paly this is a hard memory issue. Try cleaning the lens first.
    4helpful
    2answers
    Cavs DVD-202g Karaokee Player displays "No Disk"
    try to replace the ic saa7327h compact disc decoder...
    Top Cavs Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
    Are you a Cavs Televison and Video Expert? Answer questions, earn points and help others
