Nikon D300 Digital Camera Logo
Posted on Oct 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
Nikon D300 - Camera is less than a year old. Auto focus point will not move. Autofocus doesn't work. I have two lenses. Same situation with both. I'm trying to figure out if I've got a setting wrong. Best I can tell, autofocus should be ON.
  • zigmush2000 Oct 11, 2009
    show me haw to open tally
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Nov 05, 2009
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
20352
Points
160
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1330
Points
Make sure the switch around the rear selector isn't set to "L".
5 Related Answers
A
Anonymous
  • Posted on Mar 12, 2008
SOURCE: nikon d40 autofocus
Out of the box, I couldn't get a center focus shot. Out of desperation I reset the camera (push info and magnify buttons at the same time). That solved the problem.
Anonymous
  • Posted on Oct 31, 2008
SOURCE: Camera won't autofocus
I too had D50 autofocus problems and ended up buying a new D300. I then learned that my issue was in the focus areas. The D50 has five focus areas. As you look through the lens, you will see one rectangle in the center and four to the top, bottom, left and right. You should make sure that the center rectangle is highlighted. Use the round thumbdial on the back of the camera to move the focus area.
Anonymous
  • Posted on Jul 21, 2008
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Anonymous
  • Posted on Jan 19, 2009
SOURCE: Nikon 18-200 autofocus lens won't
OK I just fixed it, thanks to Ken Rockwell.com who says:
"Once in a blue moon my Nikon 18-200mm won't focus on my D200. Manual focus works fine, but the lens won't autofocus no matter what I do. It's annoying!
Of course the camera needs to be pointed at something with contrast, lines or texture. Point it at the sky and nothing autofocuses. That's normal.
One time this was so bad I thought for sure I was going to have to send my lens in for service, since nothing would get it to go.
Then I discovered the problem: I had knocked the AF switch on my D200 to M. This switch is easy to knock and I had forgotten to check the obvious. There also is a switch on the lens which is not easy to knock, but I have left the lens set to M shooting at night, and I forgot to return it to A/M the next morning.
This fixes most of my problems.
Rarer is when the lens honestly won't focus. When this happens I turn the camera off and on. If this doesn't fix it, turn the camera off, press the lens release button and rotate the lens back and fourth a couple of times. This will clear any dust off the electrical contacts and focus returns."
akangpepen
Steven Pepen
  • 133 Answers
  • Posted on Jan 03, 2011
SOURCE: Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
2helpful
2answers
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
2helpful
Which Nikon S.L.R. cameras can I use my 70/300mm AF-S Nikor and still maintain auto focus, it is currently on a D40x
Every one (assuming the camera supports autofocus in the first place, of course--old film Nikons didn't). The lens has an autofocus motor, so the camera doesn't need one.
Film Nikons supported autofocus starting with the N2000. (Actually, the F3 also had autofocus capabilities, but used a different system). All the digitals support autofocus.
2answers
Auto focus on my d300 does not work
There is a [MF - AF] switch on the camera body where the lens attaches to it.
Move the switch to the AF selection.
AF = AutoFocus
MF=ManualFocus
D300 shutter only closes at about 1/20 sec
lawsuit, take them to small claim court, Nikon will settle...
HI, I have a Nikon D300 and I lost the auto-focus function. The AF works with my lens on my D70s, so it's not the lens. Any suggestions?
You could try turning off the autofocus (on camera) and flip it back on. it may be a stuck motor or connection. May also be back CPU connections.
2answers
Nikon d40 digital camera
When the camera is in auto focus mode, it will not take the picture until it locks onto a subject. If there is not enough light, the camera will "hunt" for something to focus on. Since it can't define any edges, it won't allow the shutter to release.
The D40 base model does NOT have a powered focus lever for autofocus, so if the autofocus is not working, suspect the lens.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
