Computers & Internet Logo
Posted on Oct 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My system is not seeing the SimpleTech HD after i used it to back up my system and then formatted my system
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Oct 11, 2009
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882726
Points
4663
If you are running Vista, try these steps:
Connect the drive but do not Format the drive, right click 'my computer' then 'manage' go to 'storage/disk management' view the drives; your usb drive will not be allocated a drive letter. You can set one manually or leave it for about 2~5 minutes for one to be allocated auto. Each time you connect the drive you may have to do this.
If you weren't planning to reinstall an operating system from CD and then restore your data files, then what software did you use to "back up your system?" Did you clone the parition, or did you try to just copy all the files?
If the vista disk management solution didn't help, please repost with more information.
I have a Simple Tech external HD that has been working fine but now my PC won't recognize it and freezes up when I have it plugged in. I get the blump sound when I plug it into the USB port but t
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement.
Incompatible USB Port Problems W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts b> SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter b> If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. Enable Drive Letter View b> Click the "Start" button and choose "Control Panel" from the start menu. Click "Folder Options" and navigate to the "View" tab. Scroll down and place a mark next to "Show drive letters," then click "OK." b> Configuring Drive Manager b> Click the "Start" button to launch the start menu. Right-click "Computer" and choose "Manage" from the menu. Click "Storage" in the menu on the right side to extend the section. Click "Disk Management" under the "Storage" header. This will show you a list of drives and removable storage on your computer. It will also report the status of the drives, such as "Healthy." If the removable storage does not have a drive letter or has a drive letter in conflict with another drive, you can assign it a new letter. Right-click the icon of your removable storage drive and click "Change Drive Letter and Paths." Click the "Change" button, then choose a drive letter from the drop-down menu. Select a letter that is near to the end of the alphabet to prevent drive overlap issues. Click "OK" to allow the changes to take place. You should now see the removable storage listed with your other drives on the "My Computer" screen. SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible b> If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing. Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted. b> Replacing a Defective Hard Drive b> You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services. Hope this helps.
Won't recognize external hd
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
My fabrik simpltech 500g hd doesnt work on anything but my macbook, is it locked?
If it's formated under MAC OS, windows will never see partitions on your hdd.
2helpful
Hi! I have a 250GB Simpletech pininfarina. I stored my PC stuff on the drive, but would like to now store information from my MAC. What do I need to do to get this working with my MacBook Pro? Jeffrey
hi balkanhope
Save information on a separate hd and wait for folowing operations to be successfull : format your Pininfarina in FAT 32 . Copy data back to Pininfarina . Connect Pininfarina to Mac and proceed further on .
Best regards ,
fanaudi .
No project file to restore files from SimpleTech HD
You need to programmed method to repair project file I would suggest you new one http://www.project.repairtoolbox.com application works with .mpp file beginning with MS Project 2000 file format
1helpful
2answers
Mac OS X 10.4.11 SimpleDrive 1TB HD appears on Desktop only occasionally. Does not appear in Disk Utility. Have transferred files to it, light is on, plugged in, just takes several restarts to appear.
If you unplug the power and USB cables from the drive (but not the computer), plug in the power and then plug in the drive, the Mac will remount the drive on the desktop. I am having the same issue, only my old HDD used to be my TimeMachine drive and now I want my SimpleTech drive for that. The issue is that when the SimpleTech drive disappears, OS X automatically uses my old HDD for TimeMachine and all my disk space vanishes.
Very ARRGH!!!
I'm trying to find a better solution, because having to mess with the cables means it's no good for TimeMachine... and very frustrating on top of it.
Cant put Videos files on hd.
hi fdonald,
its prasant,
i think that its a virus prbleb.you do one thiing you back up your all document and format the hard drive.after that you put a good antivirus then put what ever you want.
if that do not work let me know.
bye
My simpledrive has disappeared and I can't get it to re-mount
have you tried plugging your HD into another computer to see if it has the same problem with another computer?
if the 2nd computer is able to detect your HD, I suggest a backup of your files and format your HD immediately. Your primary computer should be able to detect it then.
A piece of advice: try removing or unplugging your HD once in awhile. External HD is somewhat different from internal HD. :)
1helpful
My computer doesen't recognize the hard drive
you need to partition the drive in the first instance before it will do anything, ( as they are not initially partitioned) you need to go into logical drive management to partition the drive. (right click on my computer, select Manage then when the mangement screen comes up select logical drive manager, you should then be able to see your unpartitioned drive which you should then be able to partition and format)
Simpletech 500 gb external usb drive
The external hard drive can be fomatted by :
Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
Right click on the drive you will get the popup menu.
In that select the format option.
But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
Use the full format option.
Wait for sometime, until the format is completed.
Then you are good to go.
Good Luck.
Live, Love, Laugh.
Top SimpleTech Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
ExpressFiX
ExpressFiX
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
