Canon PIXMA MX850 Multifunction Printer Logo
Posted on Oct 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer says Orinter is Offline but is connected. Has the Fax button highlighted. Only have Copy, Fax, Scan, Memory Card to select from, which one should be highlighted for printing from connected PC
Xanda Frederica
Level 2:
Guru:
  • Canon Expert 183 Answers
  • Posted on Oct 11, 2009
Xanda Frederica
Canon Expert
Level 2:
Guru:
Answers
183
Questions
0
Helped
112223
Points
500
In order to print from PC you should choose COPY function. To check the connection between PC and your printer perform these steps:
  • Right click on printer driver name (Canon PIXMA MX 850 in this case)
  • Choose Properties
  • Click on Maintenance tab
  • Click View Printer Status: the status should ONLINE in order to print or scan
If still Offline,please recheck USB cable,reinstal it,or compare with another cable.
Source: Inkjet Forum
2answers
I want to download pictures from the internal memory and I attached the camera with the usb cable and it does nothing. I've tried pressing the shutter button nothing
The only way is copy pictuers from internal memory to the external memory using the camera Copy pictures or videos:
1 Press the Review button, then press the Menu button.
2 Press to highlight Copy , then press the OK button.
3 Press to highlight an option:
PICTURE or VIDEO-copies the current picture or video.
EXIT-returns to the Review menu.
ALL-copies all pictures and videos from your selected storage location to the
other location.
4 Press the OK button.
NOTE: Pictures and videos are copied, not moved. To remove pictures and videos from the original location
after copying, delete them
How to move pictures from the internal memory to the memory card
Press up/down to highlight Copy To, then press OK.
Press up/down to highlight the copy to location, then press OK.
Press up/down to highlight an option: Picture/Video, All Date, Selected, All Album, All Memory Card, All Internal Memory, then press OK.
The above is from this page of the user guide.
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
2answers
I HAVE THE X47850 SCANER HOW DO I SET THE SCANER CODE SO I CAN SCAN?
Hello.
You don't need a scanner code (pin ?) to scan. Here are the steps from Lexmark Support:
Step Action 1 Make sure the printer is configured to scan over a network. 2 Load an original document face down on the scanner glass. 3
From the control panel, press pattlnk_1182007_1150-uparrow.gif or pattlnk_1182007_1146-downarrow.gif repeatedly until Scan is highlighted. 4
Press pattlnk_1182007_1151-selectbutton.gif. 5
Press pattlnk_1182007_1150-uparrow.gif or pattlnk_1182007_1146-downarrow.gif repeatedly until the computer you want to scan to is highlighted. 6
Press pattlnk_1182007_1151-selectbutton.gif. 7
If you set a PIN during network setup and are being prompted for it:
  1. Enter the PIN using pattlnk_1182007_1151-leftarrow.gif and pattlnk_1182007_1152-rightarrow.gif to select a digit location and using pattlnk_1182007_1150-uparrow.gif and pattlnk_1182007_1146-downarrow.gif to select a value for that digit.
  2. Press pattlnk_1182007_1151-selectbutton.gif.
8
Wait until the printer has finished downloading the scan applications list. 9
Make your selections using the control panel buttons. 10
Press the green Start button (pattlnk_1182007_1144-scan%20start%20small.gif).
Hope this helps.
How do I use a micro sd card to save photos?
Before doing the steps pls format the memory card first
To transfer pictures to memory card follow the steps below:
  1. Remove the memory card slot cover, located on the upper right side of the handset
  2. Insert a microSD memory card into the memory card slot, until it locks in place
  3. From the standby screen, press the left soft key for Menu
  4. Select My Stuff (7)
  5. Highlight Graphics, using the navigation keys
  6. Press the left soft key for Options
  7. Select Open (1)
  8. Highlight desired Photo, using the navigation keys
  9. Press the left soft key for Options
  10. Select either Move (4) or Copy (5)
  11. Select either Selected (1) or Multiple (2)
    • If Multiple, highlight each Photo, using the navigation keys
    • Press thecingular%20logo%20only.jpg key to check each Photo’s box
    • Press the left soft key for either Move or Copy
    • Highlight Memory Card, using the navigation keys
    • Press the left soft key for Select
    • Highlight the Graphics folder, using the navigation keys
    • Press the left soft key for Options
    • Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  12. Highlight Memory Card, using the navigation keys
  13. Press the left soft key for Select
  14. Highlight the Graphics folder, using the navigation keys
  15. Press the left soft key for Options
  16. Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  17. Remove the microSD memory card from the memory card slot
2answers
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
13helpful
VOICENOTE TO PERSONALIZED RINGTONE ON BB CURVE 8330?? PLZ HELP!
Voice Notes to Ringtone.
If the voice note is stored on the device memory:
Go into the Media icon. Hit the BlackBerry® (menu) button and select ‘Explore’. Select ‘device memory/home/user/voice notes’. Highlight the voice note and hit the menu button. Select ‘Copy’. Hit ‘Up’ twice. Highlight the ringtones folder. Hit the menu button and click on ‘Copy Into’.
If the voice note is stored on the media card:
Go into the Media icon. Hit the BlackBerry® (menu) button and select ‘Explore’. Select ‘Media Card/BlackBerry®/voice notes’. Highlight the voice note and hit the menu button. Select ‘Copy’. Hit ‘Up’ twice. Highlight the ringtones folder. Hit the menu button and click on ‘Copy Into’.
Now the voice note will be available as a ringtone and can be assigned to a specific individual.
1helpful
2answers
Importing Music.
I had a similar problem. I did not get a USB cord with my phone. I found that if you insert the microSD card into your computer a folder opens that says Secure Digital Storage Device (E:). I have iTunes. I don't purchase music from the store (which is an option) but I download my cds to the program. If you highlight a song from the iTunes and then right click and select copy then open up the tab for the Secure Digital Storage Device (E:) then paste the item.
Remove the card from your computer and put the smaller card into your phone. Hit the menu button. Then hit the folder button located on the right side of the screen. Then select the more button. Then select the memory card. This will allow you to access the item you have on the card.
If you wish to download the item to the phone memory (meaning you can remove the card and the item will remain on the phone) you select the option button and hit copy - it will then give a prompt asking if you want to copy it to the handset memory or the memory card - select the handset memory. After this is complete you will be able to remove the microSD and still be able to access the item you downloaded.
1helpful
Kyocera mita km2030
The Memory TX is for fax transmission only, not for your print queue. Push the printer button and highlight the go button and select it. This will take your printer online (or if already online it will take it offline). If the copier was offline, it should start printing when you select go. All of this assuming that the IP address is correct and the print driver is installed on your PC.
Please don't forget to rate your answers.
old marine
old marine
ZJ Limited
ZJ Limited
