1). Immediately pick out the inner memory card of your digital camera
in case that any newly taken picture would rewrite your original photos.
2). Insert this memory card to your computer via a card Reader and
prepare to retrieve all your deleted pictures.
3). Apply a deleted photo
recovery freeware to retrieve all your deleted photos back successfully:
http://blog4mark.blogspot.com/2012/12/photo-recovery-after-delete.html
I believe this data recovery freeware can
work perfectly on your camera memory card just in the same way as it completely
retrieves all the deleted data of my friend off from his phone memory card.
Just give it a shot!
4). Save and back up all the restored photos on a different memory card
or drive in case of data recovery failure.
Note:
Never forget to back up everything important at
least on two memory cards or locations in the future.
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
SOURCE: When i turn my digital
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
SOURCE: Card error
As long as the xD card was not formatted it is possible to recover the images that were accidently erased or unable to be downloaded to computer. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and people have had much success in recovering images.
