Ryobi 4stroke brushcutter, new, OK at first, then started fading and recovering at full throttle. Changed the plug, great, then started same thing. Plug dirty? too much oil in the sump? (filled with the measured amount provided) This machine needs to earn its keep. Help.
This running pattern often indicates a lean fuel mix.
Unfortunately, with today's environmental hysteria, you probably will not be able to adjust the carburetor enough to get it to run better. If you do have any carburetor adjustment available, try turning the screw (the high speed screw, if there are two) counter-clockwise a bit. This will allow more gas into the mixture. Most small engines today have limiter caps that prevent very much carburetor adjustment.
how do i change the kawasaki kbh27c brushcutter
