SOURCE: rca remote, codes don't work for sylvania tv
Trata con esto.
Presiona el boton Code search y mantanlo asi hasta que el led se quede encendido suelta y presiona el boton TV despues vas a presionar y soltar el boton Power hasta que el televisor se apague despues presionas el boton enter y el codigo queda almacenado.
El Tv tiene que encenderse primero manualmente.
SOURCE: philips universal remote - tv codes for Sylvania
Only one code worked (out of the 13 codes provided for Sylvania TVs
with my Philips Universal Remote) so I could program my Philips
Universal Remote to operate my Sylvania 6413TC 13" TV: 0520
After manually turning on the TV:
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired Mode button (in your case -
TV). The red indicator blinks (very quickly), then stays lit.
3. Enter the 4-digit code (0520), and if it's valid, the red
indicator should turn off. (Supposedly, for an invalid code, the
red indicator flashes. However, when I tried all 13 codes, the
red indicator turned off, yet only one code actually worked. Go
figure.)
4. Press CHANNEL UP. If your TV responds, no further
programming is required. Although, some buttons on your Universal
Remote may not operate your TV. (They all worked for me, yeah!)
If 0520 does not work for you, here are all the codes provided by
Philips: 0807, 0002, 0502, 0115, 0520, 0919, 0324, 0247, 0402,
0408, 0109, 0715, 0717.
SOURCE: how can i put it on AV mode?
you will have to call the number on the back of the TV. There you can by a remote. I had the same problem.
SOURCE: i lost the remote to my sylvania model; 6419TE 19
Have you tried the search fuction,some of the remotes will search for a code that works.
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
