This is a very common issue on these units, the link below has a video that explains how to clean the drain motor yourself without calling a technician.
http://www.appliancerepairlesson.com/2011/01/21/washer-not-draining-repair-bosch-maual-door-release/
Good luck with your repair.
Do u have warentee
i have just changed my carbon brushes on a wae24162/01 bosch w machine and found a small problem you cannot get to one of the bolts properly,so what i did is cut into the metal backplate with a pair of weiss tinsnips and bend about 2" of metal out of the way,once i had done this it only took ten mins to change brushes and refit motor,simples,dave,london
SOURCE: my bosch classix 1200 fl wont spin or drain
If the washer doesnt drain it will not spin, the link below had a video that explains how to clean the drain motor yourself.
Good luck with you're repair.
