They will only go to the draft folder if you accidentally click the Save to Draft option instead of Send. It is very easy to do! If an email has been sent it will go, by default, to the Sent folder.
If you locate the email that you have replied to or sent then highlight it and then right click on it a drop down list will appear.
Select and click the View Full Headers option at the bottom of the list. This will give a popup window containing header info. If you read through it will show the following:
If you can see this then it conforms that you message has been successfully sent from you email account.
Note: It does not show or guarantee that the email has been received or read at the recipients end.
Testimonial: "great advice thanks."
Click on the draft and click send again then it will fully send.
