D-Link DP 301P (DP-301P) Print Server Logo
Posted on Dec 25, 2007
No printing threw terminal service
D-Link DP 301P Print Server been configured correctly with XP system but traying to print using terminal services without any luck
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Dec 29, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
4594
Points
6
Do you have the options set correctly on the remote computers assistant to use local devices
I have connected the d-link to a KOT printer,my network cannot find the server.And according to the manual I cannot browse the default ip of the DP-301P+ sever.please assist me immediately.
I have D link DP- 301P Print server I am using it in Epson M188D Printer for KOT Printing but its shows some times printer not found on network, please help me to solve the problem.
Ajay
2helpful
I have print server DP-301U Pls let me know the default IP address for configuration
Hi
As far as I can remember the default IP is 192.168.0 .10, subnet 255.255.255.0
If this isn't the correct IP address, you'll need to reset the d-link print server Hope this helps
Regards, c0d3
Hi sir how can i change ip address for Dlink printer server DP-301P+
Logon to the Print Server web configuration and begin managing the DP-301P+, simply launch the browser (e.g. Internet Explorer) and type dlink-xxxxxx, where xxxxxx are the last six digits of DP-301P+'s MAC address. The MAC address can be found on the bottom side of
the DP-301P+ device.
Default IP Address of DP-301P+ is set as automatically getting from DHCP server or Router with build-in DHCP server. Please note that the PC's IP Address must be in the same subnet as the print server's IP Address for the two devices to communicate. (For example, if print server's IP
Address is 192.168.0.10, with a subnet mask of 255.255.255.0, then your computer's IP Address should be 192.168.0.x, where x is a value between 1-254, excluding 10.)
For additional information, please refer to Dlink printer server DP-301P+ Product Manual
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
No light at all including power light
Check your power supply. If the transformer box is cold and the outlet has power, you'll need to replace it. You will need DC 5V, 2.5A and the correct adapter. Thus check with Dlink if your print server is still under warranty.
I hope this helps.
6helpful
2answers
How to reset the administrator password of the D-Link DP-301P+
hi
i forgot password Printer Server D_link Dp-301p
Please Help Me
I would know if D-Link DP 301P Print Server supports SNMP protocol because i need to print from IBM iseries thank you
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported :
  • BOOTP
  • SNMP
  • Telnet
  • TFTP
  • FTP
  • LPD
  • RARP
  • DHCP
Password
By default the DP 301P+ does not come with a password. If there is one installed (and you don't know what it is), you can reset the device to factory defaults from the Tools menu in the web configuration utility. Be aware that you will lose all settings in the print server when you do this.
Cheers
Nick
DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server
You need to connect to it (using the broswer at the PC of same LAN with the current ip of the print server). Then click on Tools TAB, click on "Reset" at left. You should see "Do you want to restore this device to factory default setting?". Click on "Apply"
5helpful
Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
http://support.dlink.com/products/view.asp?productid=DP%2D300U#apps
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
