If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise
If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise.
https://www.fix.com/repair/appliance/microwave/unusual-noise/
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
if its making a loud humming noise you need to remove the outer and carefully discharge the high-voltage capacitor in the magnetron circuitry(caps are usually oval in shape and 3 to 5 inches long) after this disconnect one terminal of the cap and check it for being open,then do the same on the high-voltage diode and check this for front to back resistance high in one direction and lower with the meters leads reversed on the diode,the humming is coming from the transformer not being loaded by the cap and diode to double the voltage required by the magnetron tube of -2,000 volts D.C.
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it ..
zaheer
Islamabad
yes for sure magnetron or diode has gone bad.but usually it is the mag.magnetron when go bad they start making noise and stop heating.when chaging magnetron chg the diode with it.
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
