Televison & Video Logo
Posted on Oct 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My polarido 37in hd-lcd tv makes constant buzzing sound
Eric Rotmil
Level 3:
  • Master 587 Answers
  • Posted on Oct 10, 2009
Eric Rotmil
Master
Level 3:
Answers
587
Questions
0
Helped
175529
Points
1898
Hi my name is Roety,
I can help you with your issue ,
Polaroid went bankrupt, but you can still buy the mainboard assembly.
It costs about $200- $400 search on ebay or google using the part number on the main section in the middle rear or set.
It is held in with three screws.
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Buzzing tv after power surge
Get the estimate. When your insurance company sees it, believe me, they won't buck at replacing your TV _especially since the prices of TV's have come down over the years while the quality and resolution has skyrocketed. . .
I HAVE A SVA 37in HD VR3718W tv, that just went out. we were watching it and all of a sudden it just went black like someone turned it off but you could still hear the sound..what do i need to fix it and...
Without testing the tv all i can say is that, from your description, it can be only the T-con board or the ballast for the backlighting. Take a flashlight and point it at the screen from up close - if you see the image there it's the ballast, if you don't the t-con.
These are the boards
T-con http://buy.id.ebay.com/buying/id/display/110575838928_SVA-VR3718W-LCD-Controller-Board-Part--6870C0060F
Ballast http://goo.gl/SJkA6
4helpful
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
1helpful
HELP
mainboard is bad and needs replaced with the proper rev and firmware updates. questions, email me
My tv
How mant times the the led on the front of the set blinks? And how long do it stay on before it goes out?
1helpful
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
[email protected]
Ken
Phillips 37pf7320a 37in.hdtv-ready lcd
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
37 in LCD TV
Make sure you aren't in component mode and hagve plugged in and RCA cable(Yellow, Red, and White) look back behind the TV and unplug your cables and reconnect them into the Yellow Red and White ports. Then change the TV input to Composite(Press Source until it says comopsite on the top right). That should fix your problem.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
