Ok start over
you need to be looking at the inside of the door
the frame around the glass the choke
will pop off,,
take a small flat head place it between the choke and the frame down by the hinge. pry ever so carefully it will pop out slide the screwdriver around the edge until the whole choke is dislodged
once the choke is off
you will see the two screws for the handle
you may need to lift the latch mechinism to get to the bottom one
once your done you can simply push the choke back it place you will here it snap
be careful the choke is very brittle
and will break if bent
The problem is with the lower screw, it's hidden behind the metal frame that's exposed after the choke is removed (the metal frame has pins at the top and bottom at the end closest to the oven opening that allow the door to swivel open). It looks like the only way to get access to the screw is to separate the metal frame from the outer plastic door, but it's not clear how that's done.
I have to echo hic42's comment. After removing the six screws which I think attach the metal frame to the door I can pry the top and bottom tabs from the metal frame. The tabs on the door ends are very tight and can't be freed. The metal frame doesn't move relative to the plastic door and I can't see how to separate the two to get to the bottom handle screw.
The problem was with the lower screw for the handle. The latch mechanism is irrelevant for the model I have. I eventually got to the screw but it was necessary to remove the metal frame, which took almost an hour and required using homemade wooden shims around the frame and also being very careful not to break the plastic of the door around the metal frame (very frustrating). There is no easy way to do this unless there's a special tool that GE makes available to professionals. The alternative was a very simple design modification which only required having a circular hole in the metal frame at the position of the lower screw of the handle; I guess the design engineers at GE assumed the plastic handle would last longer than the microwave itself.
Having worked as an engineer in GE Appliance Park, I was very cautious in dealing with snap-in plastic tabs. I followed instructions and promptly broke the tabs off the choke. The tabs are desired to be pushed from the inside frame out, not the way described in the instructions. I see no way of doing this without a special tool. A flat head screw driver, even a spatula, will not get the job done.
