The fact that it's tripping the breaker on the genset would suggest the the problem is not at the generator but rather on the load side of the genny before anything else I would seperate the generator from the rvs electrical system and apply some other load some thing fairly heavy toaster heater ect.. the fact that it's stopping the generator is a little unusual but it could just mean that the electriacl panel has a relay that keeps the generator running when the power dies so does the generator .load test should point you in the right direction I,ve owned 4 motor homes and when I wish you luck I realy mean it.
Good Luck
Testimonial: "Thanks a million. New discoveries- appliance turned on, throttle flips wide open,shuts down.If you manually keep it at its position,it continues."
