SOURCE: i have a crown ce4000
I believed you got 1 or 2 electrolytic capacitors were dry out so it missed 17V + or -- regulators in the preamp sections that why both side light are on If you go to 1 of the service center Crown in your town it would cost you between $100 to $200 I use Australian dollars
SOURCE: I have a Crown CE1000 power amplifier. I turned it
Unfortunately Crown amps are not the easiest to repair as they utilize multiple levels of amplification. Since you saw a flash, a resistor probable smoked, I would recommend that you bring this to an authorized service center.
Dan
SOURCE: I have a crown ce2000 amplifier that need repair is there parts
http://www.crownaudio.com/support/techsupp.htm
SOURCE: CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Testimonial: "APPRECIATE THE HELP"
Its not worth taking to a store for repairs because the cost will be more than its worth. What are the chances you think I could read up on it and attempt to fix it myself? Do you have any recommendations on where I should start?
