I plugged it in to charger . the green light comes on but it wont witch on ?
SOURCE: navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
SOURCE: buttons and screen not responding on via michelin x-950t sat nav
stick a pin in the reset hole in the back.that should fix the problem.
SOURCE: my sat nav just stays on the start up screen which
SOURCE: my tom tom sat nav wont turn on even when plugged
hi try a soft reset, first make sure your battery is full. if you use a sd card, remove it. push reset button on bottomside of your tomtom, its in the middle next to "reset" push it with a small pin, paperclip or something, for at least 15 seconds. after that push on/off button for minimum 5 seconds. if used push back sd card. good luck
