When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
When switch to carpet, the difference is that the brush roller turns. When it is on hard floors setting it doesn't. Remove the base plate, remove the brush and the belt. There is likely something wrapped around the drive spindle or clutch.
You have to find out from where the noise are coming (motor or from the front of the cleaner ) Motor- bearings or something gets in the fans of the motor Front of the cleaner- check roller and holders at the end and 2 plastic covers true which cleaner sucking from carpet. That plastics sometimes get broken and vibrate
When they get real loud either the motor bearings or the motor fan are bad and you will have to replace the motor, part #2031100, would sell for about $45.
shark vacuum making loud noise
