I tried to adjust the open and close limits, but the trolley keeps traveling so far that the track rail bends when the door closes completely. I adjusted the arm that connects the trolley with the door as straight as I could, but no good results. any suggestions? thanks!
I think you need to take the cover off the motor unit and watch the limit switch assembly in operation. Takes only a few seconds to see how it works and see if it is damaged in some way. You need to turn the down limit adjustment in the opposite direction of the arrow printed on the cover to stop the door sooner. I think the down force adjustment on the rear of the motor unit is out of adjustment also. This adjustment affects the safety of the opener and should only be adjusted high enough to consistently close the door.
