RCA HD61LPW165 61" Projection HDTV Logo
Posted on Oct 08, 2009
Tv turns on w/pic then pic dissapears light blinks 4 times
My rca m61wh74s turns on with great pic and sound,, then within a min or two the picture shuts off but the sound stays on and my power light flashes 4 times then steady on then four times again and repeats. I replaced the bulb 8 months ago when it popped very loudly and clearly was blown showing the same power light sequence. Could A bulb be bad and still light up brightly for a short time? I dont hear any unusual noises coming from inside.
  • lets_eat_ste
    lets_eat_ste Aug 15, 2012
    I have exactly the same problem. were you ever able to find a real fix? The only solution listed below isn't a solution.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
557
Points
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
2helpful
Hello, I have a RCA 61" M61WH74S rear projection
I am not sure which fan you are putting back as there are a couple. I am attaching 2 pics that show the fan locations. You may want to get the service manual for your model which shows the dissassembly proceedures. You can get it on page 2 of the service manual catagory from www.tvrepairworld.com by download within minutes of ordering service manuals are indispensable when serviceing a Television.
I have a 52'' HDTV Projection RCA tv and it went out no pic or sound so i UNPLUGGED and had to wait a month later which was today so I turned on and it had beautiful picture for about 20 min then it turned...
U have tools,can u do basic soldering,and understand basic electronic?Yes.Take ur tv aparts.Take out the DM power supply board check for dying,soon to be dead capacitors.These capacitors are alway bulges or puffing up on it tops.U replaced these dying capacitors,u will solved this power light blinking problems.Try website like Tvrepairworld.com might still sell those prepack capacitors repair kit for the RCA DLP tv DM power supply board.
6helpful
Power lite blinks 10 times. no pic no sound. cant turn on or off
red light flashes 4 times then stays on for about 5 seconds then flashes 4 times again any idea what this means and how i can fix it tv is about 4 years old and only just started doing this
2answers
TV will not turn on
can you respond to this same post and let me know if it blinks 3 times or what the number of blinks is and I will try to assist you.
Tv no pic or sound
If you hear the high voltage try to come up and set shuts down in 2 secs it could be your FBT also these sets have alot of poor connections chassis should be resolder.
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
