Harman Kardon AVR 7000 Logo
Posted on Oct 08, 2009
The volume of the center channel on my AVR 7000 is a lot lower than the fromt two channels. Is this normal. I had to adjust the setting up 10 db to equal the db of the left and right fromnt channels.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
344
Points
I have same problem
How do I add a 2 channel amp to a Denon avr 2307ci
To add a 2-channel amplifier to your Denon AVR 2307ci receiver, you can follow these general steps:
1. Determine the amplifier connection type: Check the specifications of your 2-channel amplifier and identify the available input and output options. Common connection types include RCA (analog) and speaker wire (for binding posts or terminals).
2. Identify the pre-out connections on your Denon AVR: Locate the pre-out connections on the back of your Denon AVR 2307ci receiver. These are typically labeled as "Pre Out" or "Preamp Out" and may be color-coded. You will need to find the pre-out connections for the front left and right channels.
3. Connect the RCA cables: If your amplifier has RCA inputs, use RCA cables to connect the pre-out connections of the Denon AVR to the corresponding inputs on the amplifier. Connect the left channel pre-out on the Denon to the left channel input on the amplifier, and do the same for the right channel.
4. Connect the speaker wires: If your amplifier uses speaker wire connections, connect the front left and right speaker outputs of the Denon AVR to the corresponding inputs on the amplifier using speaker wire. Make sure to observe the proper polarity (positive and negative) when connecting the wires.
5. Configure the Denon AVR settings: Access the setup menu of the Denon AVR by using the remote control or the front panel display. Navigate to the audio settings or speaker configuration section. Look for an option to enable "Preamp Mode" or "Preamp Outputs." Enable this option to ensure that the front left and right channels are redirected to the pre-out connections.
6. Set the amplifier to the correct input: If your amplifier has multiple inputs, select the input that corresponds to the connection from the Denon AVR.
7. Adjust volume and settings: After completing the connections, you may need to adjust the volume levels on both the Denon AVR and the amplifier. Use the Denon AVR as the primary volume control and adjust the amplifier's volume accordingly.
It's important to consult the user manuals for both your Denon AVR 2307ci and the 2-channel amplifier to ensure proper setup and compatibility. If you're uncertain about any specific steps or settings, it's advisable to consult the manuals or reach out to Denon customer support for assistance.
This video MIGHT help a little
1helpful
Audio problems
Click the link below for manual pages I mention to make changes:
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/AVR1700_OM_EN.pdf
Most dialog sound comes from the center channel / speaker. If not working correctly, it make become difficult to hear people talking especially if there is a lot of other sound going on in movies and some music, too.
Check and adjust the volume level for the center channel or speaker. Check page 8 of the manual to learn how to use the remote to change the volume level of individual channels or speakers.
If you want, you may find it is a good idea to check page 17 to esablish correct volume levels for each channel by runnijng the set up with the microphone. This will allow the system to be "calibrated" for the room. This is a very important step in "getting the sound right".
If none of these suggestions work, you may have a problem with the center speaker itself - or with the amplifier for the center channel.
I hope this helps & good luck!
Check the speaker connections for the center channel. Page 6 shows the location on the rear of the amplifier - but check the speaker itself first as it is easier to get to and the rear of the amp is less likely to be distrubed and have a poor connection.
I have a Behringer 1002 mixer. Applying 0 dBu unbalanced to the input I need the -10/+4 control in its most sensitive position to acheive 0 db out with the main output control set at 0 dB. Is this cor
Depends on the input you are using. First you need to calibrate signal coming in with the Gain attenuation knob. Setting this prior to adjusting your channel output volume should calibrate the signal so when the channel volume knob is set to 0 and the Main volume is set to 0, the meters should indicate a true 0 reading.Not setting the Gain correctly will affect this. On the 1/4" channel inputs, you have less adjustment and may have to adjust the item you are plugging in from its source. If you are having issues with high gain, chances are it could be a cable issue, or something from the source itself.
1helpful
Center channel is too quiet for dialogue from PS3 movies
turn the other speaker decibal levels down then increse main volume until you are satisfied.
2answers
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
2helpful
2answers
Voice volume is low compared to background music volume on AVR-2808CI
Could be a number of things.
Most likely your surround sound mode. Some people dont like Dolby. Try to switch to 5 channel stereo.
Other option is to turn the center channel speaker channel volume up. Voices and dialog come from the center channel speaker in Dolby modes. Post back if you need instructions.
Please rate my solution.
1helpful
Receiver won't let volume go higher than -7 dB
Actually, -7 db and above woul be quite load.
Anyway, I am not very familar with the Pioneer GUI auto setup. But, am aware of how AVR are set-up.
If you have set up the home theatre by auto/manual setup then please check the channel levels whether any of your channels settings is at +7.0db.
If so, reduce this setting where it more +7.0, then you would be able to raise the overall main setting from the volume control to go higher than -7db.( by as much as you've lowered the particular channel setting)
Please do let me know if this helps.
Lower volume on center
when you feel that the center channel is low compared to the other speakers, you can go to set up, speaker set up and then level calibration. here, you can actually adjust the volume output per speaker up to +12. So in your case, try to increase the db of the center speaker and see if that will help you hear it better. Hope this helps.
Hissing
Sounds like you're connected to a cable, satellite, or DVR box ("set top box"). Many times these units have their own volume controls.
Try reducing the volume of the set top box to 80% or below, preferrably somewhere between 50% and 70%. When the volume is set too high, the background noise will be amplified as well, which then gets amplified by your receiver and becomes audible.
You will need to adjust the volume level of your receiver to compensate for the lower input level, and keep in mind that some channels may have more noise than others. It'll be a balance between having all your input sources are relatively-similar input levels (so you don't have to adjust the volume a lot when switching between sources) and how much noise you can hear or ignore.
1helpful
2answers
Avr 7000
WAT BRAND SPEAKER AND RECEIVER?POSSIBLE OHM ISSUE?WAT IS THE IMPEDENCE ON THE AMP AND CENTER SPEAKER,.HAVE YOU TRIED RUNNING A 6?8 CHANNEL CONFIG?FOR EX.USING YOUR SOUND CARD THROUGH THE PREAMP AS A DSP. WHE PLAYED IN SHOP HE USESD CD? U USING SAME CONNECTION FROM THE SAME INPUY? OR IF LISTEN ING TO RADIO. SOMETIMES THE SINGNSAL IS NOT IN A DIGITAL FORMAT SO THE PPR LOGII C CANT PRODUCE IT.IT WOULD BE PLAYED ANALOGICLY.MEAN NO CENTER.
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
