Canon PowerShot A75 Digital Camera Logo
Posted on Dec 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The camara won't show a picture on the lcd screen
The camara will not show a picture on the lcd screen.
  • hermons Sep 19, 2008
    It does not take pictures & no picture on card or LCD seems to focus & flash to something in the normal manor. when new it had apicture on the lcd with vertical lines down the picture ! Checked obvious batteries lenses all appears good .
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
693
Points
The camara will not show a picture on the lcd screen when trying to take a picture. Play back mode works, put in new batters, reset to factory defaults and re formatted card...still no pic on lcd in shooting mode.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
841
Points
It eventually shows a picture but the lcd screen start out dark then screen jump. Then the light is dim help
Anonymous
Level 2:
  • Expert 137 Answers
  • Posted on Dec 24, 2007
Anonymous
Expert
Level 2:
Answers
137
Questions
Helped
36411
Points
214
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
4 Related Answers
t00nz
CameraR
  • 4738 Answers
  • Posted on Jan 26, 2008
SOURCE: Black Screen
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Anonymous
  • Posted on Mar 02, 2008
SOURCE: black screen
High, John again. I just got off of the phone with the folks at Sony. They said that it was an image sensor problem and are sending me an address label to send the camera in for repair. (at no charge).
Their number is (888) 476-6972. The call took several minutes, so get comfy and be patient.
RixsFixes
Radio Code Pro
  • 2200 Answers
  • Posted on Jul 28, 2009
SOURCE: canon camara was dropped and now it reads e18.
Hi
The Canon E18 error happens when the lens gets stuck while trying to extend. When your camera was dropped the lens mechanism was damaged resulting in this error for a jammed mechanism.
If the camera is still under warranty you should see if Canon are willing to repair it. If not you can view this link which is a very good walkthrough with pictures on how the error was resolved with a Canon SD300.
As you can see from this the process is intricate enough and involves opening the camera so should only be attempted if you feel confident about taking it on.
http://members.shaw.ca/gregs_space/Canon_E18_repair_guide_for_SD300.pdf
Hope this helps. Please remember to rate my answer. Many Thanks.
Anonymous
  • 11967 Answers
  • Posted on Oct 06, 2009
SOURCE: I hadnt used the camara for 6 months or so, and it
Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Had LG6700 8 weeks today a faded line ran down centre of screen 15 cms wide now screen won't show picture or turn on?
you can only replace lcd's not fix them, take the item back for a manufactures warranty replacement- it sounds like the lcd pixels dead or at least on its way, also a possibility the lcd controller is malfunctioning
Can you view digital camera pictures on the television screen
yes, use the plug that came with camara with ends, 1 plugs into camara, the other end will have an rca yellow video plug. plug the yellow into your aux video in on your tv. you will use the functions on camara to view, skip, etc.
I need to restart my camara.
I just got a fuji digital camera. I was taking pictures and it said memory full and then the lcd screen went dark gray with a green dot in the middle. I then opened the memory card and installed it. I can still take pictures and see thru the focus lens but not the lcd screen.????? pls. help
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
Camara not working
try reset ti factory setings. if not, maybe the camera flex needs tobe replace or the camera itself.
1helpful
2answers
Black Screen
3helpful
Lcd all white
okay, so i had this same problem..
it can only be fixed by pentax so hopefully youre camara is under warrenty. its a software error and your camara is defective.
Samsungs850 no pic in view finder
This is new. I see that according to the illustration, there is no Optical Viewfinder- thus you need the the screen to compose the images - Is this correct? As this camera is new to you carefully read up the instruction manual - especially the set up routine. If after a day or so you are still in trouble - take it back to the store for replacement. Do not interfere with the camera.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
