Question about Bosch Classixx WFO 2466 Front Load Washer
BOSCH Maxx washing machine will drain and fill but not spin. Also recently clothes are left with sludge on them. Have put on several cycles with cleaning agent.
  • Bosch Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
Posted on Jun 16, 2010
6ya staff
SOURCE:
BOSCH MAXX WFO 2062
Have you checked the outlet pipe that the machines pipe discharges into ? Sometimes these get filled up with sludge etc and may siphon back in smelly water at the end of a cycle. You could also see where the pipe drains into the sewer system , see if there is a local blockage.
Jan 08, 2014 | Washing Machines
I have a Bosch Exccel 1400 Express washing machine which has given good service now about 5 years old, Last week I noticed a stale smell as I opened the drum after the washing cycle had finished. I am a...
Hi from retired Englishman in SW France @ 21:25 Wed evening.
Someone else had this sort of problem about a week ago.
I asked him the question 'does the drain pipe go into a sink u-tube?'' because water from clothes does not smell, especially after washing and rinsing. Sink water CAN smell, especially if there is a partial blockage/sludge in its u-tube which would be shared by the washer. BTW I believe this was his problem.
There should be water in a (non-sink) washer waste pipe u-tube blocking any smells from the rest of the waste system. I suggest checking the sink/washer waste set-up first.
Also, have you cleaned the lint tray/filter recently? If not it could be a build up of sludge there.
If you unaware of where it is (on our Bosch front loader) it is behind the front lower panel - but before starting-
REMOVE POWER FROM THE MACHINE AND HAVE A WATER RECEPTACLE AND/OR RAGS TO SOAK UP ANY WATER when the filter cover is removed.
One or other of these should cure your problem I would expect.
If you have trouble removing the filter put a comment on this entry and I will receive notification that you have done and get back to you.
John C
Feb 02, 2011 | Bosch Washing Machines
Won't spin cycle
when sitting for the last spin it may be out of balance,when you have no cloyhes in it,put 1cup of HE clorox bleach and let it sit in tub over nite,then run on heavy duty wash hot water cycle.(no clothes) this should open up drain pump.this may take several trys.
Jul 31, 2010 | Bosch Washing Machines
My washing machine is washing but not drainning well and not spinning well please help model classixx 1400
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 24, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Maxx 1000 wo;nt spin
check brushes in motor 6 years quite good.
Sep 14, 2009 | Bosch Washing Machines
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch Classixx WFO 2466 Front Load Washer Logo
523 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
