Uniden TCX905 Cordless Accessory Handset and Charger Phone Logo
Posted on Dec 24, 2007
My phone will not work we plugged a nother phone and it works why does our phones not work
Make it work.Thank you
A
Anonymous
Rewire the jack. Obviously there is a wire not connected
Code lock remove
You should be able to take this to a Sprint store and have them restore if for you free back to your account.
OTC Wireless Bridge
Alright I have good news and bad news the good news is: if you remove your IP Phones the setup will work again. Once it is working plug in one of your IP phones with Laptop plugged into the bridge. Once the IP phone is connected test if the Laptop remains connected. The use another Laptop with crossover cable to connect it to the IP Phone one question (is the IP Phone acting as a bridge between the OTC Router and the Laptop?)If it is it can pull an IP address if the OTC Router is a router and the IP phone is acting as a routed interface bridge. Once you get this to work duplicate the setup for the rest of you IP phones and laptops. BTW you do realize you are pummeling the router with RTP/UDP packets? I hope this helps Thank you, Shuttle83
1helpful
I wont change my phone to english but i cant read it ita in a nother language
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
1helpful
My phone is not connected to pc phone modle is motoyouva W388 What can i do
I have for my phone a program that i got when i bought it. Without this program i cant even open it so if you have a program that came with your Motorola then install it if you dont have anything then check if your Usb port is working ok...try to connect it to a nother USB port
For about a couple of days now my fax which is a HP Officejet 5600 all-in-one, it has been showing a message that the phone is off the hook but it is not and it does not allow me to Fax anything. It is...
Plug the phone line directly into the LINE jack on the Officejet. If it works that way, buy a dual adapter and a nother line cord from your local office supply store. This will seperate the Officejet from the cordless phone.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
N73i main camera not working.......updated the firmware, did a hard reset but still to no avail.........helppppppp
try this remove the back cover of the n73 and when u remove it u will see 2 small golden slim kinda plastic chip clean that and clean the 2 small golden antena's that looks like 2 small very small sticks clean it when ur done put back the cover restart ur phone w8 for ur phone to wake up slide the cover to open the camera and check it out it worked for mine too if it dosent work something's wrong with the 2 small antena's if  u cant solv that problem go back to the same shop u bought ur phone and tell them to check it out if they cant find out tell them u want a nother nokian73 and try it out then thats it! :P
Subsidy Lock?
This is because you bought a phone from a company and you are try to use a nother companies sim card in the the phone so it will as for a subsidy code. This means that you will have to go to a company to unlock your phone.
please rate me. thank you.
May 28, 2008 • Cell Phones
1helpful
2answers
HOW DO I OPEN THE GPRS OF MY CELLPHONE LGKG220
i cant phone my net work provider it takes to long isnt there a nother way to get it on
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
