Question about Fossil Philippe Starck PH1035 Wrist Watch
PH 1080 model: when I turn on the backlight every dial turns to 8
I have a PH 1080 model, when I turn on the backlight the watch won't show me the correct hour, instead all the digits will turn to 8 (for example if the hour it's 14:35 when I turn the light on the hour displayed will be 88:88 and the same happens to the date).After the back light is off everything goes back to normal.
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Posted on Aug 24, 2007
No image. No backlighting. No sound. No image when flashlight test is performed.
Hello Linda, have you plugged it in and turn it on? I have never heard of a flashlight test, sounds promising!! Have a look for a reset button hold on for 10 seconds see if that works, Cheers Greg.
Jun 11, 2016 | LG 47LV4400 47 Class LED HDTV - 1080p,...
Alarm won't turn off on Zoo York watch.
I have a different model but this solution came up in Google and it didn't work. On mine, I tried the following: press MODE. It will show the alarm time. Then press ST/SP a few times until the little alarm icon does not show on the alarm face. If you press RESET instead of ST/SP, it will start blinking and will want you to change the alarm time instead.
Mar 14, 2012 | Watches
I purchased a Cote d' Azur watch & necklace set on a cruise ship recently, and can't seem to set the other three functions on the watch. There is only one pin but there are three addtional...
One of the dials should be seconds so you won't be setting that, the other two should be day and date, when you pull the stem and crown all the way out you can set the time there is a halfway setting ( pull the stem halfway out) if you turn one way it's the day of the week the other way is the date. Hope this helps! Also what appears to be a second hand on the dial a lot of times is actually a stopwatch.
Sep 01, 2011 | Bulova Watch
How to sethour and minute
Thank you for contacting FixYa.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Best regards. Jewel
Sep 02, 2010 | Fossil FS2919 Wrist Watch
How to set date on it?
Aug 25, 2010 | Fossil BQ9177 Wrist Watch
My wrist watch has been in a drawer for over a year. I want to wear it now. the time shows 6;13 and the date shows 8: 16. It is running correctly. How do I set it foe the correct time and date?
First you need to unscrew the crown (setting knob) of the watch. Turn dial from up to down (downwards), you will feel the knob loosen and then it will pop out gently.
Pull out the pin very gently and turn downwards to set the date. If you have a Day and Date watch, turn upwards to set the day of the week.
To set the time, pull the pin out futher and turn to set the appropriate time.
Finally push pin in and simultaneously turn upwards to screw back the pin.
Please make sure you push turn the pin tightly because most cases of Water Damaged watches are caused due to the pin being screwed up not tight enough.
Aug 17, 2010 | Watches
Second hand sticks
may be it touches marker on dial or other hands
or may be required cleaing take it to watch maker hope they will give you free quote on it .. if you are in chicago we can check your watch and give estimate for free
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph : 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Aug 28, 2009 | Armitron Watches
Unaligned hour dial
Hands need realignment any expert watch maker will do it. if you are in chicago bring it to us at
Amfix Jewelry & Watch Repair
Chicago, IL 60601
Ph : 312 641 7000
Aug 28, 2009 | Watches
"one touch backlight"
You must hold start button 3 seconds, then your backlight turn on by adjust button
Jul 18, 2009 | Nike Mettle Sledge Watch WC0040 096
Fossil Philippe Starck PH1035 Wrist Watch Logo
174 people viewed this question
Top Fossil Watches Experts
Janelle Schoonover
Janelle Schoonover
Ray Murphy
john h
Are you a Fossil Watch Expert? Answer questions, earn points and help others
