Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Oct 08, 2017
Mitsubishi Medallion format problem
I have an older Mitsubishi Medallion rear projection 1080 HD tv and the screen format is a little too large at the edges so i cant see my scores when i play video games and cant see some things at the bottom of screen. Any way to change the format? i tried pressing format but the only 2 options are the screen im given and expand which is way too large
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Feb 10, 2009
SOURCE: my t.v. wont turn on.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
Anonymous
  • 3 Answers
  • Posted on May 07, 2009
SOURCE: mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
Anonymous
  • 80 Answers
  • Posted on May 21, 2009
SOURCE: green light flashes on my 65 mitsubishi 1080
You need to replace 4 capacitors on the "DM" board. They are 1000uf and 16v. The board is located under a metal shield on the left side of the set (looking from the rear).
Anonymous
  • 14553 Answers
  • Posted on Aug 24, 2009
SOURCE: Misubishi Medallion 1080
If this is a ws-65411: it sounds like one of the two STK-392-110 convergence IC's is bad; you need to have both replaced at the same time; I do this type of repair(done hundreds of them) and most can be done right in your home.
The two ic's can be purchased on Ebay for about 12 dollars plus shipping.
This is the slow time of year for TV repair shops--find someone in your area who knows how to do this kind of repair---here shops charge 3-4 hundred but I charge 200-250 total depending on brand of set.
Shop around and if they insist on "taking set to shop" keep looking---any good tech can do this repair in your home---MAKE SURE HE CHANGES BOTH of the IC's!
I do this here for free so if this has been helpful give me a vote here.
Testimonial: "very helpful"
Anonymous
  • 5138 Answers
  • Posted on Nov 18, 2009
SOURCE: my 65 in mitsubishi medallion hdtv 1080 wont turn
Fisrt try resoldering your Boards then Ck pico fuses they are green or yellow look like resistors but are fuses 5amps or 6amps also you may need to replace Both of your STK ICs they are Big Black ICs will have Part number on them example STK392-570 Call Mats For these 1-800-628-1118 Go by number on your STKs
Testimonial: "excellent knowledge and communication! "
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
1helpful
Good morning, I am in the moving business and have a customer that wants me to move their large TV Mitsubishi medallion tv. She thinks is comes apart in two peices for easy moving and I need instructions...
If the model is a WS-65809 that sey doesnt come apart. Actually very few rear projection TVs can be seperated Some RCA TVs can be disassembled to several pieces. Also I would let customer know that because a CRT TV has three CRTs that are aligned to each other , Moving the TV will cause the convergence to be adjusted. Based on model it can be just pressing the auto convergence option with the remote, But older rear projection TVs (2003 and older) have been known to blow ICs after a move when trying to reset the convergence. The ICs weaken over age and they can blow anytime the convergence adjustment feature is used, so its always a good thing to let someone know that even if very careful when being moved there set may develop convergence issues after a move because its a 3 CRT rear projection TV
My medallion hd 1080 tv has a direct tv menu screen burnt in it and i wonder what i can do to fix it
There is only one way to fix it and that is replacing all three CRT's. Due to the cost of the CRT's at around $300.00 a piece, ($900.00 for all three), I recommend not investing the money into it unless
the set is very special to you.
I hope this helps,
Skyassoc
I have a mitsubishi Medallion hd 1080 and the picture is bad, colors off plus there is a yellow section along the top o the screen. Can this be repaired
Yes,U know how to solders?Ur convergence it dead,must replaced it with a convergence kit,use what in that kit.Tries these websites for the convergence kit.Tv repair World.com,Tv repair Kits.
15helpful
Green light flashing
This is most commonly caused by the Formatter not booting up. The cure is to replace 4 capacitors on the Formatter board 1000 mfd @ 16vdc. The Formatter is the large stand up shielded board on the left as you look in from the back of the set. The capacitors will be domed on top if bad.
TV PICTURE ISSUE
sir thers no problem with your unit its the user's fault
2helpful
2answers
Mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
2answers
1080 VS 480
Trash can it and buy a new T.V.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
