I have a LG RH277H just purchased. I have connected the aerial to DVDRec and then to TV as per instructions and tuned it. I seem to be picking up an analogue signal which is not very clear. My TV (Digital) obviously has a clear picture (and a lot more channels) and I need to know how to fix up the DVD recorder to record the same (digital) signal the TV is receiving rather than this analogue one.
Any help would be appreciated
Just
SOURCE: Is it possible to tune
Unfortunately no, it is not possible to tune Hd / Sd channels on the Panasonic DMR-E85H, because it only has an analogue TV tuner.
For Sd, you could insert a 'digibox' between the RF aerial input and the DVD, but you won't be able to get Hd currently unless you subscribe to a cable or satellite provider.
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
I had the same problem! I have the singnal connected to a digital converter box, to the recorder, and then to the tv. the digital channels work ok on the tv from the converter box. However, they do not work on the recorder.
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
SOURCE: how do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
The system menu appears on the TV.
B Use keys to highlight
{ System Menu - Channel Setup }
and press .
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use keys to highlight { Channel
Search } and press OK.
The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
Use keys to highlight { Channel Search } and press OK.
The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use keys to highlight { Modify Channel Information } and
press OK.
The channel menu appears.
2) Use keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use keys to change alphabet/ number and
use keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use keys to select { On } or { Off }, then
