My model 210 is stuck in reverse. Can you help? I just purchased this machine at an estate sale. The instruction book is included. I needed to stitch in reverse, and when I turned to the stitch length dial to permanent reverse position, it stuck and none of my sewing buddies can get it out of reverse. Can you help?
The only thing you can do to possible free the mechanism is to turn the lower dial back and forth a bit, from the position where it is in permanent reverse to the numbered area on the dial. Make sure the selector is not on the buttonhole position. That machine doesn't really have a history of that issue but anything is possible, especially if it has sat for awhile and not been used. If moisture was present where it was stored, it's possible the feed linkage is slightly rusted and simply stuck.
switch stuck on only one setting and can't be turned
