Computers & Internet Logo
Anonymous Posted on Oct 07, 2009
Every time I boot up my laptopo I have a message that states "Hotkey Utility Has Encountered A Problem and needs to Close" I Have tried everything and it has not worked
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
1991
Points
15
Reinstall the hotkey utility and reboot. If that doesn't work, uninstall the hotkey utility. Often times the files needed to uninstall are missing, so I find it is easier/quicker to install first then to try uninstalling.
Testimonial: "This did not work. I have done it several times."
Each time I go to log off on my computer I get a message that cannot close down until hotkey program finishes. I don't even know what the hot key is so have to force close down. How can I get rid off this...
I found 15 search results for hotkey errors. The hotkeys are like The "Alt", "Esc", "Ctrl", etc. The easiest fix I can think of would be to try another keyboard since they are so cheap. The other solutions are likely in Control Panel under mice and keyboards.
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
At boot time appears message 'Device Monitor Appliaction (mispell
try this:
1. download combofix and follow his steps (don not agree with recovery console)
link is here : http://www.combofixdownload.com/
notify me if problem is resolved
I recently discovered that Anytime I start my Toshiba Saetelite A105-S3611 laptop/notebook with windows Xp SP2, there is a message: ?Toshiba Power Saver?, A fatal error has occurred, this program will be...
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
2helpful
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Disney Pix 2.2 has encountered a problem and needs to close.
Try deleting and reinstalling software. Also check for any updates from the software website.
Toshiba hotkey filter application has encountered a problem and needs to close please help
Download the Hotkey app from here:
http://askiris.toshiba.com/ToshibaSupportSite/searchEntry.do
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
3answers
Power saver error 0x5
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
