Cell Phones Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot activate voicemail on the samsung tocco
I have a samsung tocco. I have setup my voicemail as in recorded my voice message however if i ring my fone it does not go to my voice mail. I have checked the user manual but it doesnt mention voicemail! Can I not activate voicemail on the tocco?? My service provider is Meteor (Ireland)
Remote Computer Rescue
Level 3:
  • Master 416 Answers
  • Posted on Oct 07, 2009
Master
Level 3:
Answers
416
Questions
0
Helped
120089
Points
1419
Access your voice mail from your phone and go through the option.....all service providers have different menu options so i cant walk you through the steps exactly, but the answer should be in personal settings or system settings.....many providers have the option of turning the automated system off....make sure its on and you will be good to go!!!! GOOD LUCK!!!!!
Set up voice mail
It's easy and you can follow below steps.
you can set up Voicemail and then record voicemail message by following these steps:
    1. Tap on Phone > Voicemail;
    2. Usually, you will be guided to automated voicemail system and you can simply follow voice prompt to set up Voicemail. If not, you have to follow these steps:
    a. Click "Set Up Now". You will be required to enter password. Tap password and then click "Done". Re-tap again and click "Done". Please keep in mind that password should be between 4-6 digits in length.
    b. Click "Custom" to record voicemail. Activate "Record" to start recording and tap "Stop" to finish recording voicemail. After you finish recording voicemail, tap on "Save".
how-to-record-a-voicemail-on-iphone-eotioun5s4qsaaff3yzmdxjb-2-0.jpg For more details, check: How to Record a Voicemail on iPhone
3answers
How do I setup my Voice Mail for the first time?
all you have to do is ring your service provider they will do it over the phone(activate it) then give u a number to ring to do your message too others and check the mail
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Voicemail number changed on samsung galaxy and can not check voicemail now
Voice mails are set up from the phone company. Your phone has no control over the voice mailing service other than assigning a speed dial to it. You should call your phone company on their customer service number and they will tell your the number to call for setting up your voice mail box.
Mar 11, 2014 • Cell Phones
6helpful
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
4helpful
2answers
How do i change the ringtone length on the samsung tocco lite gt-s5230 phone. it currently only rings for 3 seconds
if it goes to voicemail, means that you have to set the length of rings before voice mail. so you have to contact your service provider, and they can fix it on their end
Got voicemail icon on tocco lite phone dont know how to access voicemail can any one help
samsung tocco lite mobile go to voice mail and phone do not ring
Nov 13, 2009 • Cell Phones
1helpful
Voice messages on Samsung Tocco
call the voicemail number usualy its on th your sim card in contacts list or contact your network provider or look on their website - eg: 02.com
2answers
Voicemail answering
Contact your mobile service provider's helpdesk for further assistance on activating your VM
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
