Maxtor One-touch  III Mini 40 GB USB 2.0 Hard Drive Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HI I'VE BOUT A NEW LAPTOP AND PLUGGED IN MY mAXTOR one touch 4 and the laptop is not recognising it. Is it because my pc was xp and this laptop is vista? Help please
Anonymous
Level 3:
  • Master 3,153 Answers
  • Posted on Oct 07, 2009
Anonymous
Master
Level 3:
Answers
3153
Questions
Helped
1165578
Points
11010
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Azrael SRL
Level 3:
  • Master 11,800 Answers
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2564665
Points
35672
Nothing to do with the OS. First test it in another pc to make sure the problem is with the laptop and not with the drive -it might have just died.
Some drives need  more power to function than an laptop usb jack can provide. Make sure it's plugged in with the auxiliary power supply.
2helpful
Hi - I have a Maxtor One Touch III, 500GB drive (3-4 years old) that has backed up my last 3 computers running Windows XP. I'm now trying to connect it to my new laptop running Windows 7, when I run the...
Hi , it seems the 'error code that you are recieving, is due to a 'connection in the {USB}.
Try "Updating the Driver / Software!"
"Go to this "Website!"
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"Select the [Drivers] you need from the "List."
View: OneTouch III EMC Vista Update:
View: OneTouch III USB
Read below:
---> "Updates software to run in Windows Vista/XP/2000"
"Download the Drivers!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-downloads&vgnextoid=35c6069f356d3110VgnVCM100000f5ee0a0aRCRD
My computer crashed a few days ago and my one touch mini 4 was used to restore most of my files to my new computer. Before I start using my Maxtor mini4 on myu new computeer for back, do I need an...
Hi, the new computer should recognise the OneTouch and find the right drivers when you plug it in.
The SafetyDrill recovery CD does not have the drivers on it. It is just for use as a boot disc if you want to completely restore your PC with a SafetyDrill copy which has been made earlier.
There is no installation CD but the Maxtor Manager utilities, including SafetyDrill, were originally on the OneTouch drive itself and should still be there if you explore it. To install Manager click on the icon called 'Launch' (which is a green forward triangle/arrow with an orange square off centre on it)
The 'guides' file should still be on the drive too.
8helpful
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
My Maxtor one touch mini 4 is not recognised on my pc. This has happened after my pc crashed and reconfigured.
If you still have the driver disk then try to install it again. You may need to look for the driver online. You can also try a system restore. System restore is a function your computer has. You can find it in start menu/all programs/system tools
2answers
My Mac laptop running OS X 10.5.5 is not recognizing my Maxtor One Touch 4 Mini 320gb external drive. I plug it in, the light on the drive comes on, but nothing else happens.
check to make sure the drive is formatted to the FAT file system as NTFS file system is not recognised on Macs (check the drive on a PC and have the PC format the drive to the FAT file system)
Kind regards and please don't forget to rate us
Maxtor one touch 4 mini 250 GB
try plugging it in and then clicking on it in the computer section
right click on the properties tab and then click on compatibility
click in the tick box and highlight win xp
apply and ok
do not throw ii in the the bin as it can be used as a hard drive in any computer or being mini , in any laptop unit
2answers
I had my maxtor one touch 4 750 gb external hard drive installed on a dell laptop with windows xp i plugged it into a mac and installed it but couldnt get it to work so i plugged it back into my laptop and...
Hi there, I think it may be to do with the format of the harddrive - see if you used the Maxtor in a Windows XP environment it would have been formatted to suit that OS.
Is the Harddrive formatted to NTFS?
2answers
Maxtor Can't Touch
I understand the problem you are going through and it is due to the fact that win xp sp2 install an NTFS filesytem on its hard drive and this file system was designed to be secure in a way that you don't remove disk drive or add disk drives just like that.Now the best solution would be to just reinstall you xp machine with sp2 with the hard drive already in the case.In this way xp will be able to recognize it as one of its own drives and now you will have access to it.
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
