Hi! It's telling me "out of memory" both on my original card & on the brand-spanking new one I just put in. Yes, I formatted the new one. Any thoughts? ~Sarah
If you formatted the memory in the camera, and the camera can not see the available space, then you have a non-user serviceable issue. send to nikon. you can call them for online assistance, however it is unlikely you will get a different answer. good luck mark
Hi
A quick look at the manual, which found here:
http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/L610RM_EN.pdf
confirmed my suspicions that your memory card, being brand new, needs to be formatted by the camera.
If you download the manual, then the instructions are on page 16.
The manual is in pdf format so can be saved for future reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or Windows Photo Gallery or Picasa or any other photo cataloging program.
Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 secondsthen replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
The error 10 message is trying to tell you that the new memory card you have tried to put in is not compatable with your camera. AS you have already tried turning it off/on, replacing batteries etc, you can try taking all cards out, and attempt to get it to fuction correctly with original cmaera memory. After taking out all cards, and with a fully new set of batteries in, use your cameras menu to format the camera memory. Now try and take photos with just normal memory. Is it working? If it does, and error is gone, put in old memory card and reformat it. Does camera pick it up and recognise it. Can you now use it. The new card you tried to install may have been an incompatable brand. Check your manual for approved brands or your local dealer. The card could also be faulty.
