I have an F-1 error coming up and it should be an ERC problem. the beeping is inscessant, is there a way to turn the beeping off without unplugging the oven or turning the circuit breaker off?
F0 - F1 - F7
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
I have a Caloric Gas Range with an F-2 code on the display that is causing high heat and burnt food. The circuit panel shut off was the only way to turn it off. I have not attempted to restart.
Does this sound repairable? The unit is 15 years old.
