I HAVE A SYMPHONIC TV AND CANT GET IT TO PLAY A GAME THROUGH THE RCA JACKS. I LOST ORIGINAL REMOTE. SO I CANT GET INPUT BUTTON TO WORK. IS THERE A WAY I CAN CHANGE IT MANUALLY?
symphonic is well known for this-no buttons on unit for key features and a universal is not going to help either, suggest you go in search of the original remote and hang onto it.....
If using game via the RCA type jacks you use the original remote and the input button to get to those jacks. No remote and usually you are out of luck.
Yes go to menu with the buttons on your TV and go to CATV sometime u can press your channel button until your channels run out and if u keep pressing the channel button it will go into game mode or in other words switch to the RCA jacks in front of your TV
I think, after you have the rca jacks inserted into the tv and to the game you're playing, youshould be able to move the channel button down past channels 3 and 2. And or hit menu on the tv and look for setup. Try that!
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Unless the set has front panel menu buttons and the on-screen menu allows you to select the source, the answer is "no, you can't switch without the remote". If the original remote is really broken, you may be able to use an RCA-brand universal replacement that has an "input" or "source" button. Unless the original is physically damaged, before you toss it check the battery contacts inside. They sometimes get loose from handling the remote a lot and don't make good connections. Also make sure the new batteries are fresh and facing the right way.
I had this problem on a symphonic 27 inch TV I just bought from a friend
who no longer had a remote. The thing with the menu and buttons on the
front of the TV doesn't actually change the TV to true game mode. I
don't know what it acutally does, but it isn't really in game mode.
When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone
told me about) for 8 bucks at walmart and I was then able to switch to
game mode with the Input select on the remote. The remote I bought that
actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629 Make
sure you look at it before you buy it and make sure it has a button
that specifically says "input" on it. I know that some of the universal
remotes don't have an input select button or one that doesn't work. As
long as you get a Philips-Magnavox that has that button, you should be
ok. Much better solution that paying 30 bucks for a new remote
specifically for the TV. Hope this helps.
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc.
This is even written in the manual that they do not guarantee that all functionality can be used.
Here are your options:
1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need.
2. Buy the original model remote control.
3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control.
I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
