The waste ink absorber is in the bottom of the printer.You can't find it without to disassembly the hole printer.Make sure you reset correctly printer.Look here.
1) With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset
button.
2) When the Power is lit, press the Stop/Reset button two times while
pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button
(regardless of order), the printer will move into a service mode.
(Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the
table below.(Each time the Stop/Reset button is pressed, the LED lights
alternately in orange and green, starting with orange.)note: press 4
times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160) Error Code Message for Printer Canon MP145 and Canon MP160: E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink
cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
Start with printer on then run this software
Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models... E2-2 = No paper (ASF) E3-3 = Paper jam E4 = No ink E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly E8 = Waste ink absorber full, or platen waste ink absorber full E9 = The connected digital camera / video camera does not support Camera Direct Printing E14 = The Ink cartridges whose destination are wrong E15 = Ink cartridge is not installed E16 – Ink remaining is unknown E16 -E19 = Failed to scan head alignment sheet E22 = Carriage error E23 = Paper feed error E24 = Purge unit error E25 = ASF(cam) sensor error E26 = Internal temperature rise error E27 = Waste ink absorber full or platen waste ink absorber full E28 = Ink cartridge temperature rise error - E29 = EEPROM error E33 = Paper feed position error E35 15 = USB Host VBUD overcurrent error – USB E37 17 = Abnormal motor driver error E40 20 = Other hardware error E42 22 = Scanner error
printer powered off but connected on power source , you must: 1. Press & hold stop/reset button, and then press & hold [ON/OFF] button. 2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator). 3. Leave On/Off button. Printer in actually service mode. 4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top. 5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off. 6. Press On/Off button.
Hi this works with some canon priters try ir codes for reset:
1. Press and hold the POWER button 2. Turn off the printer by disconnecting the printer power cable, 3. turn on the printer, still holding the POWER button The indicator (L.E.D.) should be green. 4. Press and release the RESUME button , the indicator (L.E.D.) should be orange. 5. Press and release the RESUME button again, the indicator (L.E.D.) should be green. 6. Release both buttons. 7. Reconnect the printer cable. 8. And it should be reset.
All best: Pineworks
Found this on our site: How to clear Error Code Canon printers MP150 MP160 CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF) E3-3 Paper jam E4 No ink E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
try this method
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button. 3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting formenu selection) 4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks
0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset See waste ink counter reset procedures below. 5 times Orange Destination setting See Destination setting procedures below. 6 times Green Print head deep cleaning 11 times Orange Button / LCD checking 12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
ink absorber full
Reset Your printer.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Turn off the printer ( "Power"
button).
Hold the button "Resume" (red circle in the triangle), add a printer
(click "Power") - an indicator light green.
Hold the "Power" button, release the button "Resume".
Not releasing the "Power" button, double click "Resume" and
release both buttons.
Four times click "Resume"
Once you click "Power", to confirm the selected action (reset counter
absorber). To disable the printer "Power" button to click again.
