Question about Sylvania 6413TC 13" TV
I tried connecting a simple dvd player to the
I tried connecting a simple dvd player to a Sylvania 13 tv and FM radio's video and audio connection but there is no tv/video button... how do i veiw the dvd?
  • 56 Answers
Get an universal remote control....look for the code for the tv...and u can get the tv working.........
Posted on Oct 06, 2009
6ya staff
SOURCE:
How do you hook up a sylvania TV model#6313ce to a DVD player?
Connect the output leads of the player, often coded red (r. audio), white (L. audio) and yellow (video) to corresponding inputs on the rear of your Sylvania TV.
Jun 18, 2016 | Sylvania Televison & Video
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
I have a mocel 6427TFY sylania tv and can not get a DVD player to play though it I set tv on channel 3 and connected to video and audio connections
you would have to select the video/audio source(that you connected the DVD to) on the tv by pressing the input or video button on remote or tv front panel.
Oct 31, 2009 | Sylvania 6427TE 27" TV
I have a 19 sylvania tv that I want to connet toToshiba DVD playe
If the TV doesn't have AV input jacks, you'll need an RF converter so you can watch the DVD player on channel 3 or 4. You can find them at Radio Shack, Wal-Mart, Home Depot and most places that sell TVs for around $15. Connect the audio and video from the DVD player to the inputs on the converter, and the converter's output to the TV antenna jack. Set the TV to whichever channel the converter is set for (3 or 4, with a switch on the converter so you can choose) and you'll be in business.
Sep 14, 2009 | Sylvania Televison & Video
No audio. Video O.K. PHILIPS DVP642/37
User manual for DVP642/37:
http://www.p4c.philips.com/files/d/dvp642_37/dvp642_37_dfu_eng.pdf
Connections on page 13.
Audio setup from page 28. Page 28:
For simple stereo setup use [Downmix] > [stereo]:
[LT/RT] requires a Dolby Pro logic decoder.
Aug 31, 2009 | Philips DVP642 DVD Player
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Saa 7130 has no video
try to connect the antena or the cable in to a vcr, cable box or dvd player and then from the receiver connect the card with compositive the yellow cable. After is install click on the compositive buttom on the program. Remember that you may have to click on the auxiliar or input buttom on the vcr, cable box and Dvd player
Aug 02, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sylvania DV220SL8 DVD Player/VCR Combo
You could try cleanining it first that would be a simple solution
Go buy a video head tape or due it yourself radio shack has video head cleaner. Remove cover unplug clead small silver audio head on right side. good luck
doctor video
May 17, 2008 | Sylvania DV220SL8 DVD Player/VCR
Connecting DVD Player
when you say nothing do you mean the tv wont come on? If the tv is on can you see the words (input, volume bar, menus, etc.) do you hear audio? does the player work on another tv, since you have a sylvania tv, are you using the game button on the top of the remote to switch to the jacks on the front? Good luck :0)
Jul 07, 2007 | Sylvania 6419TC 19" TV
Sylvania 6413TC 13" TV Logo
369 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
