HP Pavilion zd8000 Notebook Logo
Posted on Oct 06, 2009
My fans left and right work but not the middle does not
I have a HP Pailion zd8000 my fans left and right work but not the middle does not. My how do i fix it? what replaces it? where do i get it
  • 1 more comment
  • Anonymous May 11, 2010
    Plz explain it bit more
  • Larry G
    Larry G Sep 05, 2019
    What is left to explain? Middle fan does not work on mine either.
  • Anonymous Dec 13, 2019
    if the PC CPU overheats, AND !the fan center is dead, clean the fan. all lint , and hair.from vent and all you see photo far below.
    this is not new, all PC pack with lint (air cooled PC)
    https://h30434.www3.hp.com/t5/Notebooks/...
    here is the cleaning it fix fan videohttps://www.youtube.com/watch?v=3hIermdB...
Adrew Jacob
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 12 Answers
  • Posted on Jan 06, 2020
Adrew Jacob
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
12
Questions
Helped
1865
Points
35
There might be any technical issues with the fan in your device.
Resolve the issues like Hp Laptop Fan Not Working on your own with the help of Link shown below or Dial +18886337151 to get an online assistant.
Visit the website:- https://www.hpsupport365.com/blog/solve-hp-laptop-fan-not-working/
Valloor
Level 1:
  • Contributor 3 Answers
  • Posted on Oct 04, 2019
Valloor
Contributor
Level 1:
Answers
Questions
0
Helped
19191
Points
6
Left fan is part of the heat sink module. Base enclosure contains the middle and right fans. Part number for base enclosure middle fan is 380029-001.Part number for the base enclosure right fan is 380027-001. Part number for the heat sink module (includes left fan and thermal paste) is 380030-001. These parts are available on ebay.ca or newegg.ca. Hope this helps.
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Oct 07, 2009
Anonymous
Contributor
Level 1:
Answers
26
Questions
Helped
6155
Points
36
Its bad go to newegg.com or eny pc store eny fan will work long as its the same size.. there cheep
  • Anonymous Dec 16, 2019
    only this fan works, and first clean yours.
    never ever guess, clean first.
    this is the center fan and is CPU fan.
    100% HP custom designed fan.
    as seen on ebay not newegg ever.
    Amazon too, if lucky.
    search ebay "HP fan 380029-001" bingo, learn to
    clean the fan first then after that see that HP parts tag, then search for that HP Part number. find it buy it and put it in, if bad.
    the videos posted show the long steps to get to it clear as day.
    all shops know how and do this all the time.
Can i adjust the fan speed in the bios on my hp zd8000
You don't have to reduce the FAN speed, because the Fan power works in PWM (Pulse Width Modulation). I.E if the CPU processing is increasing due to high process load, the fan speed changes accordingly to maintain a CPU normal temperature.
3helpful
2answers
Right one third of my zd8000 screen is malfunctioning. Any fix possible?
Sorry to say, onlyu replacement of the LCD at this point.
If this information was helpful, please rate it high. thanks
1helpful
I have a zd8000 hp laptop...MB # 374711-001 screen is good. can see win xp up and running, with a flash lite on it... but no video thinking the ATI chips are burnt..... a fan stopped working.. but replaced...
take it to a hardware tech...only he can fix it...here you may not be able to get a solution....
all hardware failures can be fixed only in a tech shop...that's the shortfall of this system here in this site.
Hp pavilion zd8000, has a problem with the graphic card; the fan went dead that on top of graphic card, so when I turn system on, after a few Minutes the screen start to lost image. Do I need to replace...
if the computer works fine for the first few minutes without the fan spinning, you probably only need to replace the fan. when the image is fading, do you get lots of flashy colors? that's mostly a sign of graphics overheating...
HP ZD8000 Some questions
When it comes to overheating, its because the laptop is in a dirty environment and what happens is the fan from the cpu is sucking up all the dirt and dust so its getting caught up between the cpu fan vent and the heatsink thus less air flow and components getting hotter.
Just make sure your laptop is in a clean environment and has enough room to breathe when running and everything will be fine.
Hp pavilion zd8000 random shut downs..?
it might be broken... Call a proffession and get it fixed
2answers
Overheating?
raise it around 6 cm above the table..
Zd8000 powers on for a few seconds then powers off then loops forever
hi
when ever cpu overheat fun runs automatically if not try to update your laptop bios . Hp website has updates of your laptop bios.
thanks
1helpful
2answers
Replacing zd8000 keyboard
No, its easy to do it yourself. You should not have too much of an issue. I would stick to a factory keyboard to avoid any incompatibility issues.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
