Canon PIXMA iP4600 Color InkJet Photo Printer Logo
Posted on Oct 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get error 1401 - print heads not installed (properly). WRONG!
The printer is new, it came with the standard cartridges, and when installing, i get the above error message and don't know what to do other than re-installing the print-heads or turning the printer on and off.
Anonymous
Level 3:
  • Master 1,049 Answers
  • Posted on Oct 06, 2009
Anonymous
Master
Level 3:
Answers
1049
Questions
Helped
286740
Points
2705
Make sure you removed all the shipping tape from the bottom of the cartridges and that you installed the cartridges in the correct bays.
2answers
Why is Alarm code 5 flashes not going away?
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head.
Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.'
From Canon error page for 'Orange light blinking 5 times':
1401/E05
Description: The print head is not installed or has not been properly installed.
1403
Description: A print head temperature sensor error has occurred.
1405
Description: Faulty data of the print head.
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
3answers
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
2helpful
2answers
Error code 1401
# scan tidak mau jalan
# lampu kedap kedip ditempat
# muncul kode error 0x00000015
4helpful
ERROR MESSAGE U051
Print head not installed,
or not properly
installed.
[1401] U051 Print head is not installed. Install
the print head.
Install the print head properly.
It may be that print head is defective or main PCB assy
1helpful
2answers
2answers
Mp 160 don't work
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
2answers
Nothing will print
5 times The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on. This might help
old marine
old marine
ZJ Limited
ZJ Limited
