LG RUMOR Cellular Phone Logo
Posted on Jan 20, 2018
My LG Rumor to cant read my pictures off my memory card.
I have an LG Rumor 2 ( yes 2) and i have tried to put my pictures on my cell phone using an SD memory card. It says that i have no pictures on my memory card. what is the best way to get pictures on my memory card with out using a USB? please help i just bought the phone and i am already frustrated
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jan 03, 2009
SOURCE: LG rumor turns on then freezes
well, you could try to turn it off for a night and then you could see if it works or you could go to the sprint store and ask them and they will give you a new phone if there is not any damage
Anonymous
  • Posted on Feb 18, 2009
SOURCE: Unlocking my LG Rumor to get T-Mobile Service
It should be the last 4 digits of your cell #....I hope this helps.....
Anonymous
  • 15 Answers
  • Posted on Jun 11, 2009
SOURCE: how do i fix a wet lg rumor?
Get it out of water immediately.Make sure phone is turned off. Take out battery, open all doors on phone and put the entire phone with the keyboard extended out inside a huge jar of raw uncooked rice, I had mine in a screw-type peanut butter jar with the phone buried. keep in a there for about three to four days.....make sure the battery is out the entire time and you dry it with soft towels,DO NOT USE A BLOW Dryer AT all.....
You can blow the water in deeper...I have the Green LG Rumour 1..
The rice will absorb the water,,,I first had the phone in cat litter till we bought the rice.
I made the mistake of taking it to Sprint that night and they turned it on and the water droplets were in the screen....DO NOT turn the phone on for about 4 days or more...make sure the phone is bone dry....About 5 days later, take the phone of the rice jar,,,,look for any signs of moisture, if none, then plug in the phone and see if the green light comes on, on the side of the screen,,,if yes...then put the battery in....if good then try out the phone's systems...I did this tonight, my round button is gone, I got my phone list copied and my pictures,,,I was most worried about my pix !
I am still trying to find a way to get my text messages back :)
Lorie
CEO
AMJ Rescue Repair Computer Co
Field Tech
Anonymous
  • 34 Answers
  • Posted on Nov 19, 2009
SOURCE: LG Rumor cell phone. Screen is blank or an array
The problem has nothing to do with the firmware, it is an issue with a cable in the phone. This cable connects the motherboard to the keyboard. When the phone is slide back and forth is causes the image to blur, get lines down the middle, or white out completely. Depending on your carrier, they should be able to:
Unscrew the phone, opening the phone up revealing the motherboard
Unscrew the motherboard
Pry the motherboard from the phone (on the other side of the motherboard there is a cable attached to it, you need to get that cable replaced)
and it's FIXED!
Anonymous
  • 821 Answers
  • Posted on Apr 16, 2010
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
2helpful
take care.
I have the LG Rumor 2 phone and when i put the micro SD card in the phone reads can't initialize music D8. How do I fix?
Did you format the SD card for your phone?
Turn off the phone and seat the SD card. Turn on the Phone and goto menu > settings > tools> memory > card memory > memory usage > options - Format card.
Is there any way to get pictures from the "assigned media" folder to my mem card on my old LG Rumor or is there maybe a way to send them via bluetooth to my new LG Rumor2 without the data cable (which of...
yes,
using the memory card...
Go to your phone picture album, select the pictures you want to move to the memory card, then choose options and scroll down to copy/move. Then select either copy which will leave a copy in your phone and make a copy on your memory card, or move which moves them to the memory card and removes them from your phone. I just did this after seeing your post
I had a memory card in my old phone and when my old phone broke i put the memory card with all my pictures and everythign in my new one and now i cant find any of the pictures from my memory card..what do...
try the sims card it has if not then tell the store u got the phone from and btw the sims card has to be the same thing for the new phone like ATNT or cricket
LG wont recognise memory card!!
DID YOU TRY TO FORMAT IT USING YOU PHONE, NOT ON YOUR LAPTOP?
Pny micro sd memory card
check out the co web site and see what they say to do
2helpful
Cannot transfer music from memory card to phone,
Before you put your songs and file on your memory card did you first insert the memory card into your phone, and then formatted it?
I have the LG Rumor as well and i haven't figured out a way to make the songs available as a ring tone yet, it only gives me the option of downloading new ringtones, and I can only play my music in the music player ='(
Lg scoop
i think that does not allow that, i will check further on this for you
Im trying to transfer music from the memory card to phone memory on lg rumor
Do you have a memory card adapter? If so stick it in the computer, put the music in the appropriate foler 'my_music' and then the phone should be able to read it. Make sure your files are in .mp3 or .wma format
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
