It is more than likly that it is your right rear door i had the same problem with my 95 . The easy way to do it with out buying parts is to take the door panal off and there are two wires that run to the back of the door splice them together that way when the door opens and the four prongs are not conected the light will come on and when it closes and makes it shut off.
Testimonial: "This will work Thanks a lot"
The little bottons on the inside of one of your doors needs to be taken off and cleaned
Testimonial: "Ok Thanks"
One of the door jam switches is malfunctioning.Open each door at a time push the door jam switch (long slender buttom in between the door hinge) all the way in release and wiggle it some.Then shut the door to see if the light goes out.
My car dosen't have the door jam swithes I don't know what turns the door ajar light off.
